A guy down the road has a Old Town Royalex canoe he stored under his deck for about 12 years. He made brackets to store it upside down well off the ground. He did not use it much pretty much just laid there. He offered to sell it to me. Overall it is in very good condition - some scraps from the river but no real damage. Looks like a couple drops of deck sealer in a couple places from when he sealed his deck on the bottom.
I would think that keeping it under a deck (garage would be better) would be okay since it keeps most of the sun off the canoe bottom but still lets there be air flow to keep it cool and dry it. Don’t know if the deck sealer spots could be removed seems like they are stuck pretty good. Any thoughts on this canoe based on being stored under a deck?
FYI - I have other options for a canoe but this is a nice canoe located close to home - guy seems honest.
If you are not familiar with canoes or
roylex get someone that is to take a look at it with you, and then if he ok’s it and the price is right, buy it.
jack L
Okay
The wife and community association don’t know this, but the whole reason I built my deck was to create a canoe rack underneath. There is nothing wrong with storing under the deck.
There is something called “cold cracks” that can occur to royalex boats that overwinter outside. Mainly this occurs in northern tier areas where it gets seriously cold. It hasn’t been in issue for me in Maryland.
JackL’s advice to bring a knowledgeable friend is solid.
~~Chip
LoL
Homeowners association - HaHa.
That is why I moved to the country … we used to have one of those. I remember a neighbor across the street put in 1 section of split rail fence on each side of his driveway and put a nice flower garden around each with climbing roses on the fence. Looked great esp when the roses bloomed - all the local neighbors complemented him. Must have pissed off someone - HOA made him rip it out. I move out about a year after that - never again.
You must smile every time you see those canoes stored
cold cracks lower value but
the boat would still paddle fine. They can occur around the gunwale attachment holes. They don’t cause the boat to fall apart, but cosmetics count as far as what a good offer is. Anyway, hopefully it has none but if it does I would make a lower offer before just walking away.
cold cracking
I thought that was with wood gunnels. I believe that this is vinyl or aluminium - is that a problem with those and royalex too?
aluminum definitely can get them
It’s expansion and contraction rate outpaces just about anything else; not the total amount it expands or contracts, just how quickly it does it because transfers heat so quickly.
Got it - it is the rate of the expansion that can cause the issue.
I don’t buy that idea
I wouldn't go so far as to categorically state that cold cracking can't occur with aluminum gunwales (not that I've ever seen a Royalex canoe that is equipped with them, since vinyl is the norm for synthetic gunwales with Royalex. Even though vinyl gunwales can have aluminum inserts, cold-cracking seems to be, at worst, extremely rare with that setup), but I don't buy the idea that it has to do with the *rate* of heat conduction, and especially not that rate is the key factor. Even if this were true, the coldest temperatures (which cause this problem) don't occur suddenly anyway. The very briefest occurrence of extreme cold set in over the course of many hours during a winter night and gradually subside over many hours as well. Further, the rate of heat transfer will have nothing to do with the temperature of the material when dealing with objects with lots of surface area relative to their mass (as is true for aluminum or vinyl gunwales), unless the temperature of the ambient air were artificially heated or cooled (that is, to change temperature faster than occurs in nature). An increased rate of heat transfer only means that if the air temperature changes rapidly, the temperature of such a material will not lag behind by as much as would be the case for some other material that conducts heat more slowly, but again, as slowly as air temperatures change in nature, any material as thin as that used in these gunwales will be virtually the same temperature as the air at all times anyway. You'd have to be talking about extremely large, massive objects for the rate of heat transfer to matter in terms of the object's temperature lagging behind or not lagging behind any normal rate of air-temperature change.
Are you saying that
this is not a concern for this canoe since I believe it has vinyl gunnels?
With due respect to your deck question,
there are other considerations you should look at.
What is your intended usage?
What model of OT canoe is this “under the deck” canoe?
I am not trying to hijack the basis of your post, but usually there are other issues of consideration for a canoe purchase. What may appear to be a “nice canoe” in looks may not be the canoe for you in functionality.
Good luck!
Yes
I don’t know if it’s completely impossible for a Royalex canoe with vinyl gunwales to get cold cracks, but I bet it’s nearly impossible, and certainly it’s exceedingly rare. It gets cold in Wisconsin and it’s not much warmer in the average storage shed than it is outside, yet when people talk about the risk of cold cracking it’s always mentioned in conjunction with wood gunwales, not vinyl.
I bet that caone is fine.
Cold cracks very unlikely and if it has them you will see them plain as day when you look at it. They are obvious.
It’s the ground or water that transfers
You take a canoe off a car top where it has been sitting in the sun and place it upside down on the ground. The temp of the aluminum that contacts the ground and within a few feet of it will drop to near ground temp in seconds. The RX hull will take substantially longer. The reason the rate plays into it is it magnifies the difference in expansion and contraction until both hull and gunwale reach the same temp. Whether you buy into the theory or why it happens or not, I have seen cold cracks on RX boats with aluminum gunwales. I know it happens. This was an explanation I was given by one boat shop and it makes sense to me.
Makes
sense with the different expansion rates especially in the situation you describe.
Depending on where you live
storing a boat under a deck in a poorly ventilated area is a bad idea.
Not applicable to this boat but I have seen galvanic reactions between humid soils and brass mostly in boats kept in warm climates under a shelter but with no airflow.
In my area there are lots of things living under the deck in the winter and gnawing damage is always possible, though I have not stuffed anything under there to check.
under a deck is usually well ventilated
It does tend to be a little more humid since it is shaded and the dirt that gets wet doesn’t dry out as quickly, but the air exchange rate is quite high. I keep some stuff under my deck because it needs ventilation.
Maybe, but I’m skeptical
For a number of reasons, I'd have to hear this from someone I know who actually saw it happen. There are just too many cases of people noticing something and thinking it just happened, when what they saw had actually been there all along, and then misinterpreting as a result. Plus, there are some really basic reasons for doubt.
1. When you lay a canoe on the ground, it's nearly impossible to find a spot where more than just a few inches of the gunwale are actually in contact with the ground. There'd be no way to cool a substantial portion of the gunwale in this way, and it can't be blamed on heat transfer to other parts of the gunwale because heat would be reabsorbed along the way by the same process it was lost at the point of soil contact. I can see the hull itself being much warmer than air temperature near the ground, but Royalex also has a lot of "give" to it when it's warm, which may be part of the reason cold-cracking is normally thought of as something happening in sub-zero temperatures rather than something that happens in paddling-type weather.
2. It would be hard to believe this happens with exposure to cold water as well, since water can never be all that cold in the first place or you aren't going paddling in it (32 degrees at coldest).
If your boat-shop guy actually saw this, that would be interesting. But it usually pays to be careful about just believing everything that people in a particular business believe. Haven't you ever run into people with years of experience who totally misunderstand certain concepts regarding the products they deal with? This happens all the time in the automotive industry, and I meet them in my line of work all the time, especially excavators who have been moving dirt their whole lives who have several wrong ideas about the nature of frost in the soil (how it forms, how deeply it propagates and why, etc.) or the mechanics of soil compaction. Just because someone works with a particular product doesn't mean they don't also jump to to false conclusions or believe unsubstantiated ideas that get passed along. So to me, this kind of thing really needs to make a lot more sense before I'll just believe it just because some guy says it's so.
All that aside, the main topic is boats in storage, and I wonder, have you ever seen a Royalex canoe with aluminum gunwales? I haven't. Some have aluminum inserts, which of course would be buffered quite a bit when it comes to temperature change.
Additional factor - more than skeptical
I thought of something else, which is so incredibly obvious I don't know how I overlooked it before. Before going into that, it helps a lot to fully explain what causes this cracking. It's not simply a matter of two lineal bodies expanding/contracting at different rates. That's the gist of it of course, but if that's all there was to it, the first thing you'd see is deformed holes where the screws go through. In actuality, this effect is multiplied by the fact that the rim of the hull is being "stretched around" the framed shape established by the inwale portions of the gunwales. This is important because it explains the tremendous propagation of the cold cracks downward from the gunwale. It also explains why loosening the gunwale screws helps so much. It reduces the dimensions of the inwale (simply loosening the screws would have no benefit in terms of two lineal bodies in contact with each other - the screws would still get forced against the holes in the hull, deforming the holes and/or exerting force on the hull). Imagine stretching a hose over a male fitting. If that fitting is even a tiny bit too large, the amount of stretching that's necessary within the sidewalls of the hose is multiplied tremendously. In the case of a canoe, the rim of the hull is being stretched around the elongated-football shape of the gunwales, and if the hull shrinks even a tiny bit in comparison to that framework, it simply tears.
And THAT is the reason that the thing your boat-shop friend is telling you can't possibly be true. Cold cracks are caused by the hull being stretched, then failing under tension. Even if the gunwale could be cooled substantially as you describe while the hull's temperature change lagged behind, and even if this occurred over the whole perimeter of the boat rather than just a small section, you can't overlook the fact that it would have the opposite effect as what's described above. Rather than stretching the rim of the hull, it would compress it (so this time the force would be exerted by the outwale rather than the inwale). It would be like shoving a rubber hose inside of a pipe with a tight fit, not stretching it over a larger fitting. The rim of the hull in this case would be in compression, not tension, and you can't rip a material by placing it in compression. It might buckle or wrinkle, but it won't tear. To get the proper kind of force, you'd need to suddenly heat the gunwales to a high temperature. How is that going to happen, especially with a material that will transfer any excess heat to its surroundings as efficiently as aluminum?
cold cracks happen with aluminum
I have seen it. I did not do extensive research on why, just took a boat repair guy at his word because it makes sense to me. You are reaching in some cases. When I flipped my canoe over, it tilted to one side, but nearly the entire gunwale on that side touched the ground. You’re over simplifying to think cracking is just tearing from pulling apart also. But I really don’t care if you accept the explanation; who knows - by some miracle you may be right. But please don’t give people the impression that cold cracks don’t occur with aluminum.
