Hello, Paddler!
Should a 260 lbs guy buy this cheap Chinese Kayak? Will it hold?
So I am looking to transition from being a bank angler to a first-time kayak angler. But I am located in Zimbabwe (look it up on the world map) and kayak fishing is virtually non-existent. The only viable option for me is to purchase something online. Chinese generic kayaks are the only things within my budget (which must cover cost + shipping + duty).
I have narrowed down my search to a kayak with the attached pic. My worry is I seem to see much bigger kayaks on all US forums. The said kayak purports to have the capacity to carry me (and some more) but I am worried the claim may be false. Should I buy the kayak?
Specs:
Length 8.85ft (2.7m)
Width 34.64 inches (88cm)
Height 17.71 inches (45cm)
Weight 52lbs (24kg)
Weight Capacity 419 lbs (190kg) Can this be true given the above dimensions
Price US$300
Comments
  • The overall weight capacity does seem a bit high given the dimensions. If you are 260 pounds and have a bunch of gear, this boat likely will sit rather low.
    Here in the States, we don't see rotomolded kayaks from China much, as the costs go up so much for shipping that it is kills any cost benefit. Most of the boats we see are still made here in the States. So can't really comment about the quality of it.
    In general, this is a very short boat which won't like to paddle in a straight line well. Good for smaller ponds or narrow slow moving rivers. If you will be on larger water, you may want a longer boat. If you are headed to the coast for open water boating, you definitely would want something longer (I personally would go at least 12 feet).
    You do have at least one African brand that is supposed to be good, and they have fishing kayaks - Stealth Kayaks. http://stealthkayaks.co.za/. I think mostly composite boats, so may be out of your price range.
  • Thanks a lot. This helps
  • Update: So I have since bought a different kayak that I found. It is called the Pioneer Ambition Angler. Its dimensions are Length 2.97m, Width 80cm, Height 30cm, Weight 22kg, Capacity 130kg. Although it does say the carrying capacity is 130kg (280 lb) I was worried this may be a false claim. Well, the kayak is holding up very well and is very comfortable and feels safe. So if anyone else out there is a heavier guy considering getting a fishing sit-on-top do not shy away from kayaks with these dimensions.
  • Great that you found a suitable kayak. Just curious how the fishing in Zimbabwe is. What sort of gamefish are available?
  • These are all great "Starter" Kayaks As far as capacity goes my Hobie Outback is 12'-6" long 33.25 wide and the capacity sticker says 419 lb. I am 200lbs and do not overload. I fish the Ocean, Bays, Lakes and rivers. This is made in the USA and is probably the most versatile and most used fishing kayak in the world. Price 2,300 with everything included. I needed to build up to my "Lexus" of Kayaks. I'm glad I made it.
  • Looks perfect. Thanks for the update.
  • It's good to know you found a suitable kayak for you
  • Glad to see you found a boat now lets us see what you catch.
    Very late response but here goes: fishing is Zimbabwe is great. I am mostly fishing for bass (an exotic if not invasive species here). Other people fish for bream (this is a general term, essentially local species resembling bigger bluegill), catfish etc. Africa's record bass was caught here (18lbs)
  • @SpinfisherBob said:
    These are all great "Starter" Kayaks As far as capacity goes my Hobie Outback is 12'-6" long 33.25 wide and the capacity sticker says 419 lb. I am 200lbs and do not overload. I fish the Ocean, Bays, Lakes and rivers. This is made in the USA and is probably the most versatile and most used fishing kayak in the world. Price 2,300 with everything included. I needed to build up to my "Lexus" of Kayaks. I'm glad I made it.!
    The Hobie seems like a great kayak. STill way out of my budget. My dream kayak is actually the Jackson Big Rig
    Great. Am loving it. My wife is practically a widow now.
    Fish.jpg 439.7K
    Invasive species endemic to Zimbabwe is largemouth bass (thanks Ray Scot & USA), local gamefish available in certain parts is Tigerfish, my favourite but rarely caught is Nembwe/Robbie/Serranochromis Robustus
  • The bottom line is that cheap Chinese kayaks are just that... cheap!
    You are trusting your life to that boat so only you can decide how much your life is worth!
    Why all the straps? Looks like they could be a entanglement hazard.
  • Why all the straps? Looks like they could be a entanglement hazard.
    They are for my unique roof rack. Very handy to pop it back up and strap it on quickly. They are however a nuisance to remove so I just keep them on there permanently. When I ride they are all inside the boat to minimise entanglement risk.
  • It seems that if there is anything that can possibly snag, wrap, bind, or twist anywhere near me it will happen, but that's me.
    I am a bit of a klutz.
    Had not thought about that. Your fears make sense. Might actually remove them...
Message Boards Close
Hello, Paddler!
