Hello, Paddler!
Post Your Trip + Submit Feedback = Free T-shirt
We would love to get your feedback on the process of adding a new community trip and we are offering a free t-shirt to the first 20 people that post a new trip and then submit your feedback using the feedback form. Be sure to use the same browser and device to post the feedback.
  1. Post your trip: https://paddling.com/paddle/trips/new/
  2. Then submit your feedback: https://form.jotform.us/paddling/user-testing-new-community-trip
Comments
  • edited May 13
    1. Its complicated and slow to load changes. The trip map takes a while to load which makes one want to hurry it along but it then catches up and drops a pin on the wrong spot. Once I tried to mark a spot on Dead River in Tavares, Florida. It logged it in as a position off the coast of Nigeria, Africa. I corrected it and it did it again! The paddle was not that long. :-)
    2. The #2 feedback form shows up as being removed by the owner.
    3. The trip report feature will likely work better for me as I get used to it and its characteristics.
    4. Water type lists, "Flat/Sheltered Water, Open Water/Ocean, River/Creek (Up to Class II), Whitewater (Class III+), Rock Gardens, Surf" It is good that you allowed more than one box to be checked. A lot of water can't be described with only one box. For example our river with no fall is 3 miles wide and 310 miles long. It can be flat, open water, river and rough as a cob in the same day.
  • repeat of #1 above -- newly added locations don't show up in the right place on the earth. doesn't seem to be a way to edit to correct them
  • I submitted a trip report a few days ago. I took two tries to get it to accept my report. I can't get the link to submit feedback to work.....form deleted by owner?????
  • @sapien @Raftergirl and @Overstreet we had an issue where the locations were not appearing correctly but that is now fixed. Could you review your trips by going to your profile? https://paddling.com/members/profile/.
    The link to the feedback form has also been fixed. (okay so that was pretty embarrassing)
    Please take a few minutes to complete the feedback form:
  • edited May 15
    done............looks good.
  • Did both.....checked my trip report and it looks good. Submitted feedback. Thanks.
  • edited May 16
    Looks correct now, thanks for the quick fix! is there a way to edit a location/POI once it's been created?
    now that some of the kinks are worked out I'll be more inclined to add and update trips :smile:
    The one other suggestion I have is if the text editor could be improved to properly embed paragraph breaks and http links.
  • "Portage" would be a useful attribute type to add to the add-location feature.
  • @sapien said:
    ..............................> The one other suggestion I have is if the text editor could be improved to properly embed paragraph breaks and http links.
    Strongly Agree.
    DP
Message Boards Close
Hello, Paddler!
