Hello, Paddler!
Advice on a stable kayak for fishing
I'm looking for a fun kayak that I also can fish from. Stability is my first priority. Easy to move around is second. Easy to paddle against a current is third. I'm looking for something that has what have become fairly standard fishing features these days... transducer compatible scupper, stadium seat, good size compartments right in front of you, etc. I'm open to suggestion, but I believe I've narrowed my choices down to a few.
OK Big Game II
Vibe Sea Ghost (either the 110 or 130)
Malibu Stealth 12
Malibu X Factor
I'd like to find something in the $800-900 price range, so I'd be looking for used on the BGII and the Malibus. And new on the Vibe. Plus I believe the Malibus gained a lot of weight at some point, and I'd prefer to keep the weight at 70lbs or less. Aren't the 2014/2015/2016 models of the Malibus in that weight range?
Of these, which would be the most stable? I'm leaning towards the Vibe or the BGII. So particularly interesting in hearing about stability between those two. I look at the weight first, then the width and carrying capacity. If those numbers aren't good, I don't need to look any further. I've considered a bunch of different kayaks, but keep coming back to the ones listed. But gain, I'm open to and would appreciate any suggestions.
Comments
  • Easy to paddle upstream with your desired outfitting? Good luck.
Message Boards Close
Hello, Paddler!
