Hello, Paddler!
Lightweight kayaks - good ones
I have been kayaking for years but am having increasing difficulty handling my 50-60 pound kayaks. They are wonderful but too heavy. I do some river (light currents), lake, coastal kayaking. Sit in mostly but do own a sit on top ocean kayak. We have a place on a river and often have company who are not yakkers. Looking for some advice on a lighter kayak. 35-45 pound range which tracks well. That is a huge problem with the lighter kayaks. The tracking. Three strokes on one side to keep it going straight. Any advice on type, style or manufacturer.
«1
Comments
  • Weight does not affect tracking. Hull shape does. What sort of kayaks have you tried. Only SOT? The lighter end of the spectrum of kayaks is going to lean more towards composite construction. I have a new Lincoln Isle au Haut that needs a good home and at 17'2" is only 42lbs. I'm not sure that's what you have in mind though.
    https://www.facebook.com/marketplace/item/1981380995514012/
    See you on the water,
    Marshall Seddon
    The River Connection, Inc.
    9 W. Market St.
    Hyde Park, NY
    845-229-0595 main
    845-242-4731 mobile
  • I'm thinking that the OP's correlating tracking and weight is because the lighter kayaks they tried must have just been shorter.
    Especially in the rec boat world, weight is often just a matter of length, and therefore tracking.
  • edited February 11
    Yes I understand that it’s length that determines tracking. It Seems though, in my limited experience, that weight is sometimes saved through making the kayaks shorter. I have four kayaks. Three are sit ins. Only SOT. What I’m looking for is a lighter kayak that tracks well.
    Are you looking for a particular length?
    One of my kayaks is 14-ft long and weighs 43#. Tracking isn't an issue; it has a skeg.
    Might be useful for us to know the makes and models of what you currently use, so we have a comparison point.
  • Epic surf ski.....sot......tracks well and light weight.
    Or a Stellar ski. Epic and Stellar make skis that are kayak like.
  • If you can find some used wood kayaks they tend to be pretty light even at 16 feet long. Maybe some 13'ish thermo formed kayaks (eddyline/Delta) . Or composite but more money . Stellar makes some light kayaks
  • Ooh great suggestions. Thank you. I have three perception Carolina kayaks at 50 pounds, and a perception access sit on top. Will check these suggestions out. Thanks for the help.
  • Epic GPX Ultra at 27 pounds and 12’11 length. Great reviews.
  • Lightweight Seakayaks:
    • Lincoln (as Marshall previously mentioned)
    • Sterling (very light, very costly)
    • Epic (& others) surf skis (as mentioned by Overstreet), fast touring kayaks (18x)
    • Warren Light Craft (is no more)
    • TurningPointBoatworks - Joey is now building a composite 'Petrel Play' (CLC)
    • others???
    Build one yourself (very light possibility)
    If you can't (or don't want to) build it yourself, check out:
    Clear Stream Custom Water Craft
    http://watercraft.clearstreamwood.com/
    (see the 'Catalog of Designs' section)
    I had a CNC Shrike-R built for me several years ago (26lbs).
  • Thanks. Great suggestions.
  • It sounds like we paddle the same type of water and have the same focus on weight and well-behaved hulls.
    As Marshall said, tracking is a function of hull shape, not length. For a given hull style, a longer hull will track better, but that doesn't mean all short boats track poorly. For what you want to do, I'm guessing 14 feet (or even 12) is enough length if the hull tracks reasonably well.
    The skis and fast touring kayaks mentioned above are all good boats and light, but not necessarily well-suited to the water you want to paddle. Plus they will be a step up in skill required and are NOT a good loaner boat for visitors with no experience, one of your intended uses.
    I tested the Epic GPX, a nice boat. The design and paddling is really good. but I found the deck too low - I had to sit with my legs mostly flat, can be difficult with knee/hip/back problems.
    I've paddled and like Lincoln kayaks but never owned one. Ditto for Eddyline.
    My lightest and best tracking boat is a 13'9" skin on frame Cape Falcon SC-1 (early version of the current F-1), weight about 33 pounds. It has a skegged stern and glides amazingly well, SOF is more durable than you might think.
    A pack canoe would do well in the types of water you want to paddle. They can be extremely light, there's a wide variation in styles and price points.
    Folders (e.g. Pakboat Saco, 12.5 ft, 20 pounds) and performance inflatables (e.g. Sea Eagle 393rl, 12'10" 35 pounds) are also an option.
    Now that you have a long list of possibles from all the posts here, I suggest looking for used boats here on p-net or the local classifieds. I started out trolling the used listings here, then looking up the boats for sale that seemed interesting - you'll soon get an idea of what's out there and what you might want. Often a used boat that you're not happy with can be resold at cost, sort of a no-cost rental to try things out.
  • The Current Designs Vision 130 composite might do the trick for you.
    I'm 5'6" and 165 lbs and find it to be quite efficient easy (for me) to keep straight and quite maneuverable when put on edge.
    I haven't paddled it on any rivers, and probably won't, since I usually take my solo canoes on shallow, twisty rivers.
  • Thank you for this. From the profile of the boat I was a bit concerned about just that issue. At 60 I sometimes have these issues. My sitting antics in a kayak can be interesting to watch!
  • edited February 12
    Yes, front deck height is a critical dimension for me. It seems I need at least 13" deck height to be comfortable. One is less locked-in to the boat, but in quiet or moderate water that's better than legs that go numb after 30 minutes. Canoes have infinite deck height, by the way, which may be one big reason why they're popular with less-flexible older paddlers...
  • Remember that durability and cost are inversely proportional to weight. Heavy means inexpensive and indestructible. Light means wonderful handling characteristics but very fragile.
  • Block coefficient determines tracking
    For most this means a fine bow
    that talers gradually from the widest point
    I have had a oack canoe for 12 years. Its a tripping model at 23 lbs
    Most would not take it in the ocean but it handles big waves well
    Its been repeated overnight trips on the Gulf of Mexico and Lake Superior
    Being open even with a spray cover it wont handle three foot dumping waves but anything below that is fine
    You paddle from a sit on the bottom position with a double blade
    Check out Placid Boatworks Shadow.
    16 feet. 22 lbs
    IIRC 22 inch wide waterline
  • edited February 14
    There was a least one mention of folding kayaks -- the lightest boats are the skin on frame type, whether commercial folding models or hand-built replicas of traditional Greenland kayaks with steam bent wood frames and urethane-coated fabric "skins". I'm 8 years older than you so I can totally relate to the yearning for kayaks that are not painful to wrangle.
    If your budget can handle it ($3000 to $4000) the Trak folding kayaks are amazing -- their 16.5' model 2.0 sea kayak looks and feel like a hardshell and sets up in 10 minutes but only weighs 42 pounds. It's fully sea worthy and, as an added bonus for those of us who are retired and have the freedom to travel, can be transported as checked luggage on airlines or carried in the trunk of a rental car or small motorhome. The company has what they call "Trak Pilots" who are a network of competent paddlers around the country who own Traks and who can be contacted to meet prospective buyers for test demos and/or to get new owners oriented with their boats. I met one of them last month with his client on a local waterway. Was extremely impressed with the Trak kayaks themselves -- my first opportunity to see them on the water in person. True objects of desire. The Traks also do something no other kayak can do: the frame has hydraulic extenders so that with the push of a button you can change the rocker of the keel to alter performance to suit conditions.
    Though I have one hardshell kayak (a 44 pound 15' Venture Easky LV) the rest of my personal fleet is folding kayaks including a 37 pound 15' 7" Feathercraft Wisper and a 27 pound 13' 6" Pakboat Quest (both capable coastal open water boats) and a custom buiklt woodframed rigid skin on frame that is 18' long but only weighs 31 pounds. It's very fast, tracks like an arrow and handles rough water very well. Surprisingly stable for a boat only 21" wide but It can be rolled back up easily, though I have not had enough practice to really do that reliably.
    I also have a Pakboat Puffin solo (an older version of the Saco that Carldelo above mentioned) a 12' sit inside kayak that only weighs 20 pounds. It's not really a boat I would take far from shore, however, though it's OK for rivers and sheltered bays. Took it with me on vacation to England last year and did not have to pay any excess baggage fees.
    True-ish, but not completely true. Most SOF are light, only some are fragile, many are quite robust.
  • Even beyond SOFs, a well-constructed composite boat can be both very light and very durable. What it can't be is inexpensive, as it requires more expensive materials (S-glass, Kevlar, Carbon fiber, foam core) and manufacturing processes (vacuum-bagging), plus tight quality control.
    If one has the patience, some hand tools and a place to work, a skin on frame can be built for a couple hundred dollars. And they are incredibly tough. As demonstrated:
  • Remember that just about any wood or composite craft doesn't like impacts with rocks very much and pretty much can never be launched or dragged on rocks. We live on the water with a very rocky beach, ergo anything but rotomolded would be highly inappropriate. I found out just how weak wood was in the face of these rocks and came running back to heavy plastic with my tail between my legs.
    Of course weight for me is not an issue because the water is literally "at the end of our backyard". That said you can get a dolley and you can even lift the kayak and load one end on the racks first, than the others. There are ways of getting plastic to work for you.
  • There you have it. The entire gamut of kayak types and materials. The looking is fun!
    Please let us know what you get.
  • Thank you all very much. I’m on it. Will look into all these options and will let you know. Thanks for the advice
  • FWIW... Take a scale with you when shopping for kayaks to get an accurate weight and avoid all the hype...
    While I wouldn't choose a cedar strip kayak for rock gardening, fiberglass boats are incredibly tough. I've launched and landed on numerous rocky beaches and dragged many a 'glass boat across them. Sure, they get scratched, but so do rotomolded boats. The difference is that you can repair gelcoat, but there's nothing you can do for a shredded poly boat.
    I don't understand why you insist on portraying composite boats as delicate...they aren't.
  • My downriver boat is a Ruahine Swallow from New Zealand, and is composite, and is incredibly tough. It is designed to bounce off the occasional rock at speed and stay intact. At 17'8" and 30 pounds. I would certainly consider it light, but as has been mentioned, the combination of lightweight and strong doesn't come cheap, although I picked it up used for a great deal.
    For some great examples of the durability of composite boats, check out John Kazimierczyk's Millbrook Boats. While mostly canoes, they are designed for whitewater use and definitely aren't delicate!
  • edited February 15
    I have found fiberglass to be very durable. I have a 1972 Mohawk tandem fiberglass canoe that has come off a flatbed truck at 50 mph and is still ticking, but two heavy for me at my age to handle alone.
    I have two Kevlar canoes a solo and a tandem. The solo is 15' 6" long of S-glass and Kevlar and weights 35 pounds. The tandem is 16' long and 52 pounds. With 60 pounds of gear and 2 men pushing it close to 450 pounds total in the boat. I have hit more than one rock running rapids with it. I have repaired only one minor ding in the bow. I have seen plastic boats with big dents in their bow doing the same thing. I don't consider either type delicate. However, there is definitely a considerable weight and price difference. Though repairing composite boats is much easier.
  • My mother was avoiding a lot of great kayaking opportunities with her 50lb wilderness Systems because of the trouble she was having managing the kayak off the water due to having a tougher time with is weight as she got a bit older. Seemed to sneak up on her! That all changed after she bought her Eddyline Rio. At just over 11 feet, it doesn’t track as well as what she’s used to, but certainly good enough for her all day paddles with friends or even large organized paddles. And the weight, or “lack there of”, was a more than worthwhile trade off. At 35 pounds it has made the difference of simply kayaking or NOT. I have a Fathom myself along with a couple of other brand of kayaks and due to weight, often choose the thermoformed Eddyline for most conditions I find myself on day or long weekend adventures. This is not meant to try to promote a brand, just what I’ve tried. I certainly don’t have the valuable experience or knowledge that many of the regulars on this forum do. I just know what I saw work for my mom and thought to share. Cheers!
  • @Jimmy: The Rio is a sweet boat. Great decision by your mom since she still has the joy of paddling and more importantly, it's a safe rec kayak with deck rigging and bulkheads fore and aft.
    For that reason I will promote Eddyline when it comes to safety. Every kayak they produce has two sealed bulkheads, including their 10-footer. I think they're the only ABS manufacturer who does that. Delta doesn't. Hurricane's entire Santee series (including their 14-footer) have only one bulkhead and lack deck rigging.
  • My experience in sit-in kayaking is limited to one boat, an Eddyline Equinox. 14 feet long, 45 pounds, no rudder, only paddled on large lakes, rivers, and it tracks great. The wind has to start pushing 1-2 foot quartering tailwind waves before I start getting annoyed with tracking. Bounced it off concrete and the occasional hidden tree stump with some scratches. The only major damage was catching the top of a submerged metal fence post (imagine nails on a chalk board) and it didn't feel good and certainly didn't sound good and, when I got it out of the water, it didn't look good. Fixing that ugly scar is my only repair on the boat so far. My thought process when buying it was "If it ain't easy to move, I probably won't use it as much." Moving it from storage rack to roof rack is not a problem nor is carrying it to the water.
  • edited February 21
    Hornbeck 's New Tricks canoe series are very light (26.6 lbs), slender (16' and 23.25") and should track well: http://www.hornbeckboats.com/boats_ft_16.php
    It costs $2200 though.
    I paid $700 for a used Pakboats Quest 135 (Skin-on-frame folding kayalk, 29 lbs, 13.5', 23"). It tracks well in my hands and is nimble and durable. In water, it presents a slight v hull shape (which helps tracking) and good secondary stability. It takes about 30 minutes to assemble. But loading, strapping and unloading a hardshell kayak from/onto a car wouldn't take much less time either.
    Most of the drop stitch inflatable kayaks have very flat bottoms, which may not make them track very well. But experienced paddlers can probably compensate that with good paddling techniques.
    You can use a light folding kayak cart too, if you like: https://www.academy.com/shop/pdp/magellan-outdoors-deluxe-kayak-cart
  • The Eddyline Rio (35 lbs.) and Equinox (45 lbs) have been mentioned and are both solid choices. The Rio is a much smaller volume boat. Someone mentioned Current Designs Vision 130. I have one of those in the carbon/kevlar layup and it's wonderfully versatile and weighs less than 40 lbs. The more commonly available composite layup of the Vision 130 weights only 40 pounds. It's responsive and tracks well. The Stellars are lightweight, fast and worth a look.
  • i have a Pungo Ultralite...2 things i have noticed so far ...ultralights don't like the wind and the material they are made from, do not like being dropped or rammed into things ..I have had to have the stern plastic welded after dropping it and putting a 6 in.split in the transom end. As Far a tracking goes ,because they are lighter overall ...the input from paddle strokes seems to have a bigger effect on them directionally than on the heavier plastic boats . PS : ultra light materials DO NOT like cold, frigid waters !!!!!
    Maybe some don't, but some do. :)
  • Hi all..tried out a few and picked the pakboat quest 150. Unfortunately when I went to order one I was told that they are not available. Pakboats warehouse suffered a fire in early April. Nearly 100 brand new boats were destroyed. The Quest and Saco models were entirely wiped out. Some Saranac kayaks are now available, since the new shipment of that model hadn't arrived prior to the fire. It will be late Spring of 2020 before any of the destroyed boats will again be available. Thought you all might like to know.
    I heard that line in a song, but it wasn't about boats.
    :D
  • Wow, that is a real bummer about Pakboat's fire. First I heard of it. I have been recommending their kayaks to people for years -- have owned 4 Pakboat models myself and have corresponded with the owner and staff on numerous occasions. With Feathercraft and Folbot out of business, having a disaster like this is a real blow to the domestic folder market.
    I have two 14' Pakboat Swifts (the model that preceded the Quests) that I will be selling soon if you might be interested. I bought them 2 summers ago from a couple who got them as wedding gifts and used them only once so the frames and skins are like new. But hey need new sponsons (the inflatable skin tightening and buoyancy tubes that run along the sides) and I got materials and Boston valves to make new ones, just have not gotten around to that yet. I set up my workspace this week and pulled together all the components so I may get around to that before the month is out.
  • Sterling......good, lightweight
  • edited June 2
    BarracudaCool -- I just sent you a private message with a link to a used Quest 150 that was just posted for sale -- pretty good deal with a lot of accessories.
    By the way, the Pakboat "sling" seats are really comfortable. The 150 has the same one as my Quest 135. I'lm 68 and lightness and a seat that does not make me stiffen up are big factors for me in a kayak -- the Quest checks both boxes.
    And $$$$$
  • Thank you so much. Will take a look. There is also a used one on the pakboats site I’ve inquired about. Gad two months researching this and now I really have to have one!!
  • I bought my Quest 135 from Pakboat as a used demo -- it was in like new condition.
    Just a warning, they are not great at updating the website and the "specials" listed on it. So give them a call to check on availability. Or send them an email -- they have usually gotten back to me within a day or two.
  • I love a good skin-on-frame kayak.
    The fateful words of a Paddling addict.
  • Marshall is 100% correct: it's hull shape and not weight. My Lincoln Seguin is 42 pounds and 15.5 feet. It tracks really, really, well.
  • Weight vs. Length. This 18' Greenland replica skin on frame (my favorite kayak in the current "fleet") weighs 31 pounds:
Message Boards Close
Hello, Paddler!
