I like it! It actually feels like it was intended for a fairly lightweight adult. Yet the kneebumps allow plenty of freedom of movement for the legs. I will probably replace the minicell thighbrace pads I glued on with something a little thicker, when the time comes. Until then, it’s fine as is, perfectly rollable, and I’ve been paddling it for almost 7 years now.
The boat is quick if you give it halfway decent effort. It is easier to edge than the Explorer LV despite not having as snug a cockpit fit (and as noted, adding thicker minicell is an option). I don’t know if it is “faster” than the Explorer, but it is easier to maintain a good cruising speed in…must be the narrower width. Stability is very good, less than in the Explorer, but more than enough for light paddlers. The knee bumps seem to add stability when angled way over.
One thing I love is the small hung glass seat. This is the only stock seat that felt right for me without any changes. They offer it in two sizes. I even kept the stock seat band, but instead of letting it sit the usual way, I tucked the bottom edge of the band behind the raised rear lip of the seat. That way, it is low enough for my taste. It stays put nicely.
The bow has fairly good volume. It was not prone to pearling in surf. However, when paddling out or anytime in bigger chop, it can be a bopper. It doesn’t cut through, but rises up and then whaps down. At least, it does for me.
It has the usual trait of weathercocking, easily controlled. I rarely use the skeg.
When reverse paddling, it is harder to keep straight than the regular (shorter) Pilgrim, or the Tempest 165 I used to have. That’s the only quibble I have. Oh, and the weight. It is not a light boat, but that’s nothing unusual for a standard glass layup.
If you get a chance to demo one, do it! There aren’t many narrow sea kayaks unless you count SOF.
