I will make a few points about this video. I have a question. How many years ago was this video produce?
1: He is certainly right about the news media playing alarmist with the scientific information, and it sells. He leaves out that some media outlets aren’t above misinforming people about the science. That outrage also sells.
2: The current science has been progressing more quickly in recent years. The current science has shown that through measurements that the Greenland ice sheet is melting faster than earlier information accounted for. Not through modeling
3: The cloud cover is a validly complex issue. However, Clouds are not the only thing that reflects sunlight. The ice cover at the poles and higher elevations is another. That was not mentioned and can easily be measured. It is decreasing at an ever-increasing rate. This is not modeling it is measurement.
4: He is correct about modeling being an inexact science in many cases. However, it must still be of some usefulness as long as you know its limits. Otherwise, why would it be used in economics, engineering, as well as in many of sciences if it wasn’t?
5: He is absolutely right about how long CO2 stays in the atmosphere. I even pointed that out earlier in this thread. His apparent conclusion is that if that is so why should we stop pumping even more into the air. Since we will only slow it because we can’t rapidly lower what is now there. Does that really make sense? because we can’t rapidly lower what is now there.
6: I don’t know of any climate scientist that says climate is not complex.
7: My personal observation is that weathermen and climate scientist do not say the weather events are created by climate change. In fact, they say these events are what normally occur. What they do say is climate change is impacting the severity and the latest science is attempting to place a value to that amount.
8: Also, he was not privy to what is happening now. Smoke from Canadian fires covering large areas of this country and even reaching Europe. The frequency of events rated once in a hundred or thousand years happening in greater frequency than that estimate. Heat waves may not be more common, but they are currently more extreme. The drought in the west hadn’t been seen as that severe in over 1,000 years. The number of record-breaking temps worldwide are more numerous than they have even been. He obviously wasn’t aware of what is currently happening or the current science when he made the video.
9: We are making rapid improvement in sustainable energy that isn’t fossil fuel based. The technology in the field is rapidly improving because money is being spent to do so. Because there is a will to lower the inputs of CO2 in the atmosphere. Planting trees and possible technologies of CO2 extraction are being developed. These are long range plans trying to amend the current situation.
In my opinion there is a hubris on displayed in video on totally discounting what others are presenting, and an apparent bias in the support of fossil fuels. He is correct that the economic impact of just going cold turkey with fossil fuels would be enormous but does not address the very real need to begin limiting their use.
Bud, have you looked at the 2 NASA video links I posted. I have watched 2 of the links you posted. I did so to get a handle on what you are saying and give it consideration. I think it is a good thing to be able to have this type of discussion. I would certainly like to hear your take on them.
In having posted again I will quote directly from the show “The Spranos”.
“Just when I thought I was out, they pull me back in!”
