Lewmar and grapple anchors
have 2 attachment points. One at the “hook” end and one at the end of the shank. You use a shackle at the “hook” end and tie your anchor line to that. Then you lay the line along the shank and use a piece of ~20lb mono-filament fishing line to tie the line to the hole at the end of the shank. Tied this way, should the anchor get stuck, you can tug on the rope, break the mono and the line will pull the anchor by the “hook” end which reverses the direction of the pull on the “hook” and the anchor releases from the bottom.
when did he come up for air?
great idea, thanks
not bad Hataryoneh
Again,
a sharp knife is essential…just in case.
To commit a seppuku?
kayak anchors
Two anchor weights for kayak anchors are one and a half and 3 pounds. Generally, 3 pounds is the best weight to use, but that depend on many factors. For example
The Cooper kayak Anchor, one of the little one fits in the palm of your hand and weighs only 230 grams.
Here you can read everything about Kayak Anchors, how to use them Properly, and a lot of manufacturers: http://www.craigmarine.info/accessories/anchoring_docking/KayakandCanoe-Anchors-and-anchor-types.htm
