As many mentioned
most likely a kink, fray or smidgen of rust build up somewhere.
The in water versus out could maybe have to do with more or less weight or tension on the skeg as it floats or boat in motion.
Just some thoughts, I once also was a bike mechanic and the cables must slide freely or things don’t work.
Anychance you or a piece of gear is resting against the cable or casing.
But no I don’t have any experience with skegs
Brian
SoFlo
Update…
the sticking issue persisted until the other day when i plopped it down on the dock before raising the skeg.
the skeg slammed back up into its housing pretty hard–i was sure i busted it.
lo and behold it works perfectly now.
musta been some crud in the cable-housing or something just jarred loose.
go figure.
