Priorities not congruent? Or maybe no one has ever commissioned Winters to do a kayak with a matching list of requirements. His priorities are those of his customers, to which he applies his theories/ideas/skills.
You can’t really say all the VCP’s are alike either… Your VCP Aquanaut probably paddles a lot more like my QCC Q700 than my VCP Pintail!
The Aquanaut hull profile is based on the Pintail. It is a half inch narrower with much less rocker and is, of course, longer.
As a result the Aquanaut tracks better and is faster than a Pintail while retaining a very lively hull.
I would guess that the Aquanaut's feel is somewhere between your 700 and Pintail.
While it is certainly true that different Valley models handle differently, all that I have paddled share a liveliness on the water that is greater than many other boats (including NDK).
According to Aquanaut’s Design Statement The Aquanaut was developed from the Avocet. They added length and center volume, while reducing the rocker to increase speed, tracking and storage. If you look at a picture of the Avocet and the Aquanaut, the designs are nearly identical. Essentially, a “stretch” Avocet.
I believe the Aquanaut design is a total departure from the Nordkapp, which has more of a clipper bow, finer ends and a more rounded hull. Having paddled both, they feel totally different to me. The Pintail is also quite a bit different than the Aquanaut in my opinion. Again a more rounded hull, lots of rocker and much lower volume.
Nonetheless, whatever its design origins, the Aquanaut is a tremendous all-around kayak and on my short list.
Explorer/ Aquanaut I’m wilsoj2’s wife w/ the NDK Explorer (LV) - it’s a little of a non-sequetor at this point in the thread but I thought I’d put in a response to an earlier comment that the Aquanaut may lie between an Explorer and the QCC600 (or was it 700?). I paddled the Aquanaut a teeny bit when we were trying out boats at MikCo. I am also guessing that the QCC boat mentioned has characteristics that are generally not so far afield from my other boat, a CD Squall.
In sum I’d say that’s not a bad call. While I am not familiar w/the QCC boat, like the QCC line the Squall has no rocker and tracks like a train (no rudder needed). It handles dimensional water and turning in a much stiffer manner than the LV. The first of the above two also come thru strongly in the Aquanaut, with the break being that the 'naut carves a very fluid turn.
The 'naut does have a more active hull than either the Squall or the LV. It just adores rolling well over onto its side.
In following seas the 'naut seems to maintain its interest in tracking and has great glide, as does the Squall (I never used the rudder there either). For the LV, a little bit of skeg goes a long way.
Rocker QCC (at least the 700) may not be highly rockered - but it has more that you might think. It is far from flat. Pointy ends give the illusion of more rocker on Brit designs - but upsweep and rocker are not the same thing. Pictures of QCCs look completely flat, but it just ain’t so.
I have a Q700 and Pintail close enough to touch both as I type this. Most would assume HUGE differnces in many areas that simply aren’t there. Different? Yes, quite. Radically? - no.
Can’t comment on CD Squall - but I would not assume any similarity to Q600/700s. CD currrently has nothing really like a QCC hull. Maybe when the CD Stratus comes out, but that will likely be a bit more like the EPIC it is desigend to beat.
To add to the VCP design progression, its:
ANAS ACUTA - then Pintail (rounded rockered Anas - hence same name de-Latinized) -Avocet-Argonaut-Aquanaut, and not sure where the venerable Nordkapp fits, always assumed it was first.
Aquanaut Lineage That’s for the clarification Jim, I left the Argonaut out of the equation. I’m hoping to do some test paddles shortly of some VCPs and other boats for possible Hudson River duty.
Anas Acuta The Anas came before the Pintail. The Anas is based on a kayak built for Ken Taylor by Emanuele Korneilsen of Illorsuit Greenland, in 1959. The Anas went through some revisions, including “adapting it to the European build”.
Earlier this month at the Delmarva Retreat (Qajaq USA Greenland event) Ken Taylor brought a replica of his original Greenland kayak. We got some interesting pictures comparing this replica to the Anas. They are most different in the side view.
