Thanks!
That was fast! I suppose you racers type quick too.
That makes sense, and is an interesting way around (over) the problem.
So would it be possible to use this technique with a fast rec boat like a MinnII or a Jensen 17?
Popping a Jensen
Both boats you mentioned will pop. The trick is to know that the very shallow water is coming and then paddle hard enough to lift the hull onto the pressure wave rebounding off the shallow bottom. An empty Minnesota II is so close to a race hull it behaves like one. The 17’ Jensen is much harder crank up to the necessary speed.
The Baldpaddler has done it on a good day being chased by the devil.
Bill
On plane?
This sounds like you’re putting your hulls into the planing regime - a flat fore-hull would help this. I guess that’s why you hear about it in canoes, but not kayaks.
No planing
It’s not planing, just riding a wave. Works with kayaks too.
Alan
It is simple.
It is surfing your own wake basically.
As you come into the shallows ("suck water") the low water puts your brakes on, and as soon as the front bow wake catches up to you, you give a super hard paddle, and sort of bounce up on it, and then just keep doing it.
Recently we did two different river races that were very low, and used it on many of the sand bars that we crossed.
On one of them we had been neck and neck with two other canoes and were behind them both. Neither of them knew how to do it, and we came off that particular bar in front of them.
The first one we were in our Jensen 17, and the second in our comp cruiser
jack L
Got it - surfing the bow wave - cool
yeah my version
my version in describing.
When you paddle there is a bow wake (small wave) flowing-moving forward with the boat in the same direction and outward.
This was is HIGHER than the surrounding water…just look next time you paddle.
In shallow water…and we’re talking shallow…under a foot lets say as as little as 5 inches deeps…that wave/wake i mentioned above basically takes up all the water in that shallow depth.
If you paddle fast…i.e sprint…the canoe will NOW for a moment (maybe 3-20 seconds) with actually be going faster than that wake i mentioned above. SO if it is NOW going fast it ALSO “popped” up ONTOP of that wake and is being pulled along by the wake…ie. the forward motion of the wave is “surfing” your canoe sort of…thus the canoe is higher out of the water…making it NOT hot bottom in the shallows, AND is being pulled along-forward by the wake…
This only last a short time as mentioned above…since most cannot maintain the 80-100 stroke rate per minute to keep it up for long periods AND the shallow part will most likely end and become deep again so its no longer neeeded.
It is beautiful
when you can pop it and keep it going. Takes practice and stamina. I once saw Tim Jones pass us like we were standing still. We were in 2-3 feet and Tim was as close to shore as he could get. Dang guy made his solo fly.
I remember about five or six years ago
paddling with you on Mtn Island lake, and you wanted to practice “popping the shallows”
I thought you were nuts !
I just wanted speed in deep water.
I still do, but that kind of practice is good every now and then.
Jack L
Popping myths
Explain again how you can surf a wave that hasn’t yet been created?
Popping the hull exists, no doubt. John Winters discusses what occurs, a matter of wave theory and drag changes.
Don’t doubt
I don’t doubt you’re right in that we’re all wrong in our explanations, I’m certainly no expert and am just repeating what I’ve heard and how I explain it to myself.
The one thing that always bothered me about the explanation of jumping ahead of the wave is that if that was the case shouldn’t it be easier to do in deeper (2-4’) water since it should take longer for that energy to reflect off the bottom and harder to do in very shallow water? Instead it’s the opposite.
Alan
It doesn’t work for you since…
you are so damn fast that your bow wake never catches up to you as you plane over a few inches of water.
It only works for us slow pokes !
jack L
Surfing the bow wave, I think
I know that waves in shallow water have a speed limit based on depth (actually square root of depth). This is why waves crash at the beach - as a wave train progresses towards shore, the ones nearer to the beach slow down due to decreasing depth. The waves behind are still moving quickly, so catch up and overtake the nearer wave. This process of waves catching up to the ones in front leads to a buildup of water and the wave becomes taller until it breaks.
If you’re paddling in shallow water, you are creating a bow wave at the speed of the boat. If the water is shallow enough, the boat speed may exceed the wave speed, so the bow wave, once it’s been created must slow down. If you can manage to maintain boat speed, that means you can overtake your own bow wave and surf on it. I think this may be what is happening during ‘popping’.
wave
it is a wonderful thing!!! will let ya pass another boat in very shallow water. it also is something you must feel like a side wake
check out the governing equations
Suck water starts at 1/2 the waterline length of a displacement hull. That is the wavelength at which a surface gravity wave starts to “feel” bottom. It gets progressively worse until you hit “pop” water.
“Popped” water happens when you can push your speed to the speed that would generate a wave that would “break” in the depth of the water in which you’re paddling.
Check out the governing equations for waves in an oceanography text. The speed and depth at which lightweight paddle craft “pop” is pretty close to the speed and wavelength at which a surface gravity wave would break in shallow water. Waves tend to break or topple when depth is 1/10th of the wave length. That would be about 21" for an 18’ boat being held at hull speed. Of course, with a boat you’ve got to sustain that speed. And you’ve got to overcome the wave you’re already pushing as it starts to interact with the bottom. And if you’re right on the border of popped/not popped you might end up shoving a shallow water wave ahead of yourself which is going to create crazy amounts of resistance. If you’re in 3-4’ of water you’d have to go at the hull speed of a 30’ or 40’ boat to pop. That is why we call that water “suck water”. I know that in my k1 that if I’m exceeding a speed that correlates to a wave of length(X) that breaks in depth(D) I’m popped. If I’m paddling near hullspeed in 3’ of water? I’m slammed up behind a wall of shallow water wave.
When you pop the boat you may not be literally “surfing” your own wave. You may actually be forcing the hull into a speed range where it is behaving more like the “foamy” of a broken wave (anybody that surfs knows how fast the foam pile moves relative to the water underneath). It is a lot like planing. The shape of the wash (at least in my k1) is V-shaped much like the wake off of a boat on plane. The wake off the boat is definitely shaped differently than the wake off of a boat running at displacement speeds in deep water.
To further confound things, the shape of the hull and trim make a tremendous difference. You’ve got to be able to force the water under the hull so that you skim forward.
Sounds like we agree
You have a much richer vocabulary for the phenomenon, but it sounds like we agree on the mechanism. The one thing I would change is the statement that a wave will break at a specific depth, say 1/10 of its wavelength. Breaking requires a slope in the bottom topography - the depth gradient causes the sequential change in the speed of translation of the wave train that leads to breaking.
PS Now that I've thought about it, maybe you mean, when a wave from deeper water ~enters~ a channel that is 1/10 its wavelength, it will break. That sounds exactly right.
Winters’ thoughts
Was just poking around the interwebs tonight and found a post from John Winters on the subject, you can see the thread here:
http://www.myccr.com/SectionForums/viewtopic.php?f=49&t=32683
I’m in no position to argue with him.
Alan
Thanks Alan, and Mr. Winters
I particularly like this part “This lacks the drama of boats leaping over their bow waves but it avoids the difficulty of having to explain how the boat travels down the front of a wave it has yet to create.”
It seems that often in science we confuse the model or the simplified explanation with the reality. Of course, “why” doesn’t really matter to the paddler as long as they know “what” to do. Interesting phenomenon, though, and it is great that I keep learning new things about canoes.
no disagreement, just trying to add
Yeah on the wavelength-depth thing. I was just giving the simplest answer and wasn’t specific enough. No, the wave will not necessarily break at a depth of 1/10th wavelength. That’s just a rule of thumb for a wave entering shallower water. It either breaks or becomes a shallow water wave somewhere near that depth/wavelength ratio. The speed of the wave (is proportional to wavelenght), angle relative to the bottom contours, shape of the bottom, steepness of the slope, all affect whether the wave breaks or not and the shape of the wave when it breaks.
I wasn’t disagreeing. I thought I was adding. It is interesting to me to consider the behavior of waves as they encounter shallow water when thinking about the behavior of a canoe or kayak encountering shallow water.
thanks, I was looking for that
I tried to describe the change in wavemaking that occurs in my earlier post when I mentioned the change in the shape of the wake created but Mr. Winters does a better job.
“”"“and water depth) the bow wave system takes on a concave shape (radiating from the bow and when viewed from above) roughly at right angles to the direction of travel. The speed at this point is aproximately Froude Number 0.99 with the wave traveling at the same speed as the boat and the wave-making effect concentrated in one wave. With additional power (creating a speed of aproximately Froude Number 1.4), the wave pattern changes to one of diagonal waves only (convex when viewed from above radiating from the bow) and the resistance falls to levels below that in deep water.”""""
That transverse wave that is propogating out at right angles to the direction of travel is neat unless you’re the engine making it. My lake is fairly shallow. One day a yacht pushed me 2000m in about 7:20 in my k1. I was about 30m to his starboard and stayed in front of him the whole way. I actually wasn’t working that hard. He couldn’t understand how I stayed in front of him. He had the Detroits gagged and the harder those Diesels gagged the better ride I got. He had no clue that his 40ton vessel was producing that wave.
There’s a great graphic of the effect somewhere I’ll post if I can find it.
