Car topping and accelerated tire wear?
Yes but
I have very bad luck with tire longevity and uneven tread wear. I usually get about half of the tire’s rated life, and usually run into uneven wear early on. I buy medium-quality tires and rotate them every 3-6000 miles.
I don’t think tire wear this has anything to do with transporting a kayak. I think it’s more things like alignment, rotation, etc. On my current set of tires there was an undiagnosed failing axle that made the car pull for over a year and probably hastened the demise of the tires. Finally the axle broke and the car straightened out as soon as the axle was replaced.
few things to consider
– Last Updated: May-01-12 8:10 PM EST –
Type of driving: freeway vs. local/city
Other changes in driving conditions
Same or similar tires?
Rotation frequency
PROPER rotation
Proper alignment
Proper brake function (I know, but it really can make a difference)
Change in driving habits
significantly unbalanced load (I'd be dubious this is causing it)
That’s the thing
Most of these were unchanged.
? Other changes in driving conditions
  • Same or similar tires?
    Rotation frequency
    PROPER rotation
    Proper alignment
  • significantly unbalanced load (I’d be dubious this is causing it)
    Of course, these were different cars and therefore different tires.
    And the other change is the kayak!
    Road-wise, I traded city roads full of pot holes (New York City) with curvy country lanes. I would have thought the trade-off pretty much balanced out. But I can’t be sure of that.
I’m not sure that…
…what you are doing is Car Talk approved:
http://cars.cartalk.com/content/advice/tirepressure.html
I use a calibrated gauge (wasn’t cheap) and run my tires maybe a pound or two over the car manufacturer’s suggestions, which is nowhere near the tire’s sidewall rating.
