Here is a question for you older folks who used to backpack.
Kelty sold accessory D-rings that could be mounted to their pack frames via the 1/4" clevis pins that held the pack bag to the frame. Handy accessory, but noisy little devils unless in use with a shock cord.
But I digress. I would love to locate some of these for various outfitting chores. So far all I can find are 1" D rings without the SS band for mounting. As I recall the bands were about 1/2" with the rings sized accordingly.
Any sources known to the collective wisdom of P-Net?
Similar, but different:
http://www.duckworksbbs.com/hardware/shackles/sd090125-55/index.htm
-- Last Updated: Jan-30-08 7:37 PM EST --
Not as strong
but a whole lot quieter. North Water makes a plastic D-ring with a flat piece of plastic molded onto the flat side. It’s designed to be sewn onto something or my favorite application, slipping them between a hull and gunwale for a tiedown point. Just drill a hole through them and rivet into place.
http://www.middletonsboats.com/canoes/cpics/northwater_canoe/1-inch_D-Ring_Slider_Ladder_Lock.jpg
It’s the lower left piece.
As close as I can tell
http://www.strapworks.com/D_Ring_w_Clip_p/ssdrc.htm
is what I am looking for, although as memory serves the Kelty units were 1/2". Still, Strapworks is the only source I see that offers a SS strap attachment.
Thanks for the link!
