I hang both my legs off the side after I put butt in seat, also to drain water out of shoes. Actually, I hang both off the sides, then cross one leg before me and pull the shoe’s heel so that water runs out (involves some “dynamic edging”), then put that leg inside and repeat the procedure on the other leg. Obviously doable ONLY in calm water. I cannot fathom paddling that way for long, though. Can’t get much semblance of power when paddling with legs out, never mind torso rotation. I did get some incredulous stares and comments in WA when I did this, but it really wasn’t hard; I didn’t do it in breaking waves and even if I capsized I would have just laughed.
Then there are the fun memories of paddling with both legs on the front deck in my first boat, a rec kayak. And seeing someone in a long sea kayak go by giving me the dirtiest look, like “What a moron.” I had seen someone else do it, also in a rec kayak, and on those hot days it was enjoyable for a little while. Some people need to lighten up and enjoy trying silly but harmless things. The technique, such that it is, might come in handy in strange situations.
If the seat didn’t get in the way, I would sit backwards in the kayak and try paddling it that way to see what happens. I have sat on the rear deck facing forward and paddled it–very shakily!–but although I have sat facing backwards in the seat I have never tried paddling it that way. Next time…legs would have to be either hanging off the sides or on the rear deck.
Back to the original topic now.
Yesterday I compared paddling with legs/feet in three gradations from widest to narrowest. Widest is “normal frog”, the position that one would naturally default into in a particular kayak. Narrowest is knees together and poking up through the front of the keyhole (with no wiggle room on their sides) and feet flat on floor. Middle is where I paddle, which is a little inboard of normal frog. In that position, my feet are still on the footpegs and thighs still are under the thigh braces, with some vertical space (enough for a small degree of pumping). But there must be about 2", between the outside of each thigh and the hull side. I realized that middle had become my normal position over the years of paddling this kayak. Because I remember being annoyed by feeling the skeg cable sheath on my left side, “normal frog” must have been where I started in it. Middle is a compromise position, I suppose.
Oh, yeah, another thing. I had moved the seat 2 cm forward a few weeks ago. Gonna keep it there, as any increase in weathercocking is minor, and the blades enter the water that much further forward. Seems to work very well in my case.
