My Favs
I’m always buying new kayaking hats, looking for the perfect one.
My current hands-down favorite, for fitness kayaking and racing, is the OR ventilated “swift caps” or the “sun runner” with the neck cape: http://www.outdoorresearch.com/en/or-gear/hats/sun-runner-cap.html
http://www.outdoorresearch.com/en/or-gear/hats/swift-cap.html
For touring, my favorite is the large brim REI Paddler’s hat at http://www.rei.com/product/847874/rei-paddlers-hat. It has good ventilation and a stiff-brim that can stand-up to a stiff breeze.
Tilley’s are made well, but unfortunately I just can’t escape looking like an (old) dork in mine. The REI hat actually makes me look good, which is quite amazing, actually… :^)
One issue with the REI hat is that instead of many sizes, they offer only two: S/M and L/XL. On my noggin, one is slightly too tight and the other is slightly too big, even with the hat adjustments. I went with the S/M and keep the hat in a hat-stretcher to stretch/maintain a comfortable fit.
Here in the deep south the Sunday Afternoons Adventure Hat (http://www.sundayafternoons.com/adventure-hat.html) is very popular. It works well, but being basically a sun bonnet, it looks more flattering on women than men, IMO. If vanity is not a deal-breaker, it’s a great hat.
Of course, if you’re a Nigel Foster fan, you will want one of these: http://windagainstcurrent.files.wordpress.com/2012/03/noname.jpg
Greg Stamer
Hat
I have been using an old cotton baseball type hat for years. It has a extra long brim that really shades my eyes. Since I always have a bandana around my neck, I don’t worry about sunburn back there. I think cotton is key as it breaths and if you soak it then put it on, it will keep you cool. Some cheap hats use cardboard to stiffen the brim - not good! I remember an episode of Survivorman where he cooked some roots by adding hot stones to the water in his Tiley (I think) - pretty cool.
self-confessed hat freak
I admit to 40 year obsession with finding the perfect outdoor hat, with the parameters getting ever more specific as I’ve gotten more into paddling both canoes and kayaks. Probably gone through several dozen, some of which were 90% what I wanted but each needed improvement.
But I think I found the perfect one last week, The only problem could be locating another one as backup (or to recommend to others.) I stumbled upon it in a Tractor Supply store in a rural town along the Susquehanna. At $12.99 there was little to lose. It resembles the REI boonie that Greg favors with a couple of nifty options. Not only is the brim just the right width and reinforced with flotation material (so it isn’t floppy – a fault I have found with most Columbias), they added the float/insulation to the crown. The perimeter of the crown is solid skeeter mesh, but stiffer than that found in most ventilated boonies so the crown doesn’t rest against your scalp, but it is still crushable. The brim has a narrow reflective tape sewn around the edge and the underside is dark green to shade the eyes and prevent off-water reflection (a problem I have had with white hats. The rest of the hat is khaki tan except that they lined the crown piece with International Orange which makes it easy to spot if it blows off. They also installed a velcro secured pocket inside the crown that would fit ID, a spare car key and some folding cash. It has a generous “French Foreign Legion” back neck gaiter flap that folds up handily into a pocket inside the back of the brim rather than into the crown, so the band size is not affected. The inside sweat band is generous and soft absorbent material. The chin strap is sturdier cord than most, soft tubular nylon that goes through a pair of wide spaced grommets on both sides of the crown so that you can secure it both behind your neck and under your chin. I could not have designed a more perfect noggin bucket.
It looks great but the best part is all the features work splendidly. It’s the most comfortable, cool and secure hat I’ve ever used. Took it on its maiden voyage on Memorial Day down the Class I and II (and one Class IV that nearly ate me backwards when I missed the line) Red Moshannon Creek in gusty winds – it didn’t budge and my head didn’t get sweaty at all. The brim is the perfect depth for eye shading without blocking vision. I water tested it and it floats like styrofoam.
The maker is the ubiquitous Dorfman Pacific and the model seems to be DE-108. At least that seems to be the closest one I could find “leafing” through the PDF of their 100 page hat catalog.
Before I take this hat out again I’m going to take a Sharpie pen and write my contact ID and “$50 reward for return” on the inside. And now I’ll have to check every Tractor Supply I spot in our travels to find another one (or two) in case of loss.
BTW, I’ve tried both Tilley and Filson Tin hats. Neither was my cup of tea. I have too much hair and they were beastly hot. I do think a Filson gives a guy a bit of Indiana Jones panache (in fact our chief investigator at the last archaeology dig I volunteered at wore one all the time) but Tilleys make every guy look like Tim Allen’s neighbor Wilson (or Detective Provenza on “The Closer”).
http://uptownmessenger.com/wp-content/uploads/2013/01/GW-Bailey.jpg
I 2nd the boonie
You can pick them up from any military surplus store. You often can find them in many different colors and camo paterns as well. I used to have one that was orange camo a log time ago. Rocking the navy digi and a white camo one right now.
dang
Looks like DPC dumped that perfect boonie hat I found – I don’t see the model in their 2012 or 2013 catalogs. That’s what I get for falling for stuff scrounged off the clearance racks in backwater stores. Might have to up the “reward for return” on that label.
Is this it?
http://www.tahoemountainsports.com/product/dorfman-pacific-discovery-expedition-sailing-hat
It's currently available at Sierra Trading Post for $22 - if this is the one, you should buy out your size (I'm a hatophile as well, still kicking myself for not buying a certain polystraw I saw a couple of years ago which was discontinued...)
http://www.sierratradingpost.com/discovery-expedition-sailing-hat-upf-50-plus--for-men-and-women~p~5779k/?filterString=mens-hats~d~4885%2FDorfman-Pacific-Headwear~b~1658%2F&colorFamily=02
That’s it!
Carl, you’re my hero! Just ordered two from Sierra Trading, since I know my sweetie is going to covet it – in fact he already uses several of my castoff hats. Good thing we have the same fat heads.
Cool, glad to help, nm
Similar…
…to what I use.
http://sfkdesign.blogspot.com/2011/06/dakine-indo-surf-hat.html
The straps keep it down on windy days or the occasional swim.
Great Replys
Thanks, I will use info. and go from there. Best to you all; Ravenwolf;
protect nose and ears
Sun is cool but vicious. Tilleys will help protect against sun-borne cancers and work very well in soothing the eyes in bright sunlight and poring rain, especially if you wear glasses. I’m on my second Tilley (first one still going strong). Good stuff, expensive, but good, expensive, but last a long time. Highly recommend one.
Floating is best feature
When you’re hot, just drop it on the water, roll, pick it up and continue on your merry way.
Hats Experience
On the water a full brim hat is more than a fashion statement, it is a necessity. My father drummed this into me as a young child, and I’ve always worn a full brim whether lounging on the beach or in a power boat. I’ve even been mocked for it though they seem more popular now. Of course, the habit continued when I became addicted to paddle sports.
As for the hat, any hat is better than none. However, full coverage is essential. Ball caps with only a bill do not protect ears. I’ve worn many military surplus and cheap knock offs over the years all of which served me well.
However, the Tilley is the best I’ve experienced.
Mine is 8 years old and looks like an ancient relic from the salt and sun exposure. It is still as good as new though.
cost to lost consideration
Another hesitancy I have about costly hats like Tilleys is the gear price corollary of Murphy’s Law – the chance of your losing a hat in any given season is directly proportional to the cost of said hat. I’ve lost several $25 to $40 hats, some within weeks of purchase. The one I’ve kept longest is a quite ugly cotton twill boonie I picked up at a convenience store clearance bin for $1.99 five years ago.
This corollary also applies to umbrellas. When I used to commute on public transport a good bumbershoot was essential for long walks to stops and long waits for weather delayed buses. I lost nice umbrellas regularly. Then, caught in an unexpected downpour, I dashed into a junk shop downtown and grabbed a $2 umbrella that was the ugliest thing you ever saw – bilious yellow vinyl printed with black roses and the handle was a plastic fake wood duck’s head with red rhinestone eyes. I had that thing for close to ten years, until it was so bent, faded and shredded it had to be discarded. I couldn’t lose the thing if I tried. If I accidently left it behind in a restaurant or bus, people would run after me to see I got it back. As in “please get this hideous thing out of my sight.”
tilley
I have to say that as much as I hate the look of the tilley and generally wait until away from shore to put in on…its an awesome hat for paddling. I use mine mostly for kayaking. It will stay on my head when I roll, I can stash it under my deck lines when rolling a lot and it will stayput better than a ball cap, it provides protection to the neck on a sunny day, it will not blow off my head in 20 knot wiends, and it floats. Hate the way it looks but it sure is practical.
Not quite to the point where I will wear socks with sandles but am becomming less concerned about appearances as I get older.
Matt
I have several
have several, including a Tilley Air Flow that looks like it’s been to my mother in law’s and back (hint hint).
Last your I picked up an ExOfficio BugsAway® Adventure Hat, and it is my new favorite for paddling. It’s light weight and not a big sail, yet offers excellent sun protection. It looks better in person than in the picture too. http://www.exofficio.com/products/details/bugsaway-adventure-hat-f12
Yep.
I’m just not vain enough to avoid such a wonderfully functional hat for mere aesthetic reasons
