How to modify kayak seat to improve comfort?
LIke others, I have taken the stock seats out of several kayaks and replaced with a homemade minicell seat. Very easy to make (I use a Sureform Shaver). I like my seats long, with the legs slightly higher than my butt. No more pins and needles for me.
But there is one more thing you can do to increase leg comfort in your skegged Impex. Take out your footpegs and carve a minicell plate to put against the front bulkhead. Your paddling comfort will improve dramatically, as you will be able to shift your feet up, down, left, right, together, apart – anything you want. That is the only reason I paddle skegged boats: they allow for a bulkead foot plate. Once you try it, you won’t go back to footpegs.
Can the molded seat be removed and the screwholes sealed?
Some people paddle with just a piece of thin minicell on the floor or a Thermarest pad. Not what I like, but obviously people vary in what works for them.
As previously suggested, I am thinking about trying a piece of mimicell foam against the bulkhead instead of using the foot pegs. My concern is will this foot pressure against the bulkhead over time lead to bulkhead leaking? I have an Eddyline Skylark. Will this be detrimental to my bulk head?
I’ve installed 3" thick minicell foam footrests in each of my three kayaks: Eddyline Samba, Fathom LV, and CD Prana LV. I’ve left the OEM footpegs in place and use them to support the L/R sides of the foam footrest. The center is supported by a foam block which does rest against the bulkhead, but most support comes from the footpegs.
I use http://kayakoutfitting.com/ for my outfitting needs. Excellent company to work with and wide variety of product.
If you’re padding a bulkhead and find that you need a lot of foam (a common issue for shorter paddlers), you can use the blue polystyrene insulation from a home center or building supplier. It’s inexpensive, very light and one sheet can provide several layers of bulkhead pads. Use Minicel foam for the final layer in order to provide some cushion. I also attach Minicel wedges for my feet, angled at forward at the top 15 degrees. I find this to be much more comfortable than pressing on a flat bulkhead pad.
In boats where I’ve added a lot of padding, I make a hole in the center of each layer and run a cord through them all, attached to a stick or disk on the forward side of the most forward pad. This allows the entire stack to be pulled out easily, if necessary. I also make a groove in the pads along the keel line to allow any water that gets in to drain back out. This has worked great in my petite girlfriend’s boats.
Changing the footrest to a full-width plate, angled at 60 degrees, is a game changer.
If you don’t want to go the custom bulkhead route, there are some commercial products available, I put a “big foot” foot plate in my Rapier 20. Expensive and heavier than I prefer, but robust: http://expeditionkayaks.blogspot.com/2015/03/rob-mercer-ek-bigfoot-footplate-system.html
They make a similar plate without the rudder pedals (skeg foot).
I decided not to install a full-height (hull to deck) footplate, as the half-footplate allows me to push my heels under the plate for a good stretch, which is a godsend for long hours in the cockpit. If you install a foam footrest, you might want to leave a hole in the center for the same purpose.
Most skis and “go-fast” kayaks use a 60 degree angle for the footrest. 90 is not ergonomic and is uncomfortable and lower angles (like 45 degrees) have the irritating tendency to cause your feet to slide up the ramp during leg drive.
ONNO used to sell a carbon plate that connected to small plastic footpegs (but wasn’t angled). It would be pretty easy to make something similar from plywood or glass.
Warning – any footbrace modification that you make, test it to ensure it doesn’t pose an entrapment hazard (shoes lace entanglement, feet “stuck” should you ender and slam the bow into the bottom, etc).
For seat comfort on long multi-day races, I use a pad cut from a Thermarest Z-lite foam mattress, and top with a thin teflon pad. This gives comfort for bony butts plus allows you to rotate.
Greg
Honestly, stretching and just getting used to it helps a lot. You can add a cushion/ padding, but it will hinder your technique some. If your not worried about that then pad that baby up!
Wow, thanks for this. I am still trying to sort out my Impex Force 5 garbage seat.
What bnystrom said :+1: :+1: :+1:
in my ww kayaks I pretty routinely add a seat pad for height and add a few shims to the rear of the seat. This seems to help my 5’10" frame and short torso fit better in boats that are designed for more athletic individuals.
A few closed minicell shims/wedges do wonders under the very back of the seat pad and help with the pelvic tilt. So my posture improves when I add these. Such a simple fix that makes a big difference.
I’m more comfortable in narrow ww kayaks since my legs are less splayed out (hip replacements). When I was younger I rarely thought about outfitting and comfort. Now it is a top priority. I jump in a boat to see how comfortable I am in it. Next, I see if I can roll it. How it paddles and behaves on the water is a distant third on my list- I can adjust my technique to compensate for that…but if a boat ain’t comfortable I ain’t gonna wanna to paddle it.
