If you’re new to kayaking and looking for advice, read Archimedes . . . Read Archimedes! That will take the mystery out of “buoyancy”, “displacement” and “wetted surface”. No need to reinvent the concept:
An object floats if it displaces an equal weight of water. To match the load carrying capacity of a short, fat, shallow draft boat, a narrower boat that weighs the same must be made longer or deeper to carry the same load. LENGTH “enables” the boat to reach higher speeds before it creates the bow wave and trough explained by the “hull speed” concept. The important point from the hull speed chart is how length increases the speed “potential” of the boat, not how fast the boat will go. Only that it becomes exponentially more difficult to power through the building bow wave and trough, as the boat approaches the listed hull speed.
Water will not compress. Therefore, a wider boat MUST push the displaced water further in order to pass through. Then that displaced water returns as the boat passes. Advanced specialty hull designs have found ways to minimize the bow wave and trough that hampers traditional boat hull designs.
Short boats also climb wave peaks and plunge into the trough of the next wave (with the bulk of that wave washing over the short deck and into the cockpit. Long boats are less disrupted by waves because they can better bridge the wave peaks.
If there is more wetted surface in a longer hull, the effect is only minor and at slow speeds; by the time boats reach cruising speed, the advantage favors the longer boat.
The greatest impact on speed potential is boat length, with other influence being hull form and underwater profile, width, and weight (a “typical” 12 ft boat weighs less that a 14 ft boat which weighs less than a 17 ft boat, unless the longer boat is made of a lighter composite. If a 12 ft boat weighs 54 lbs and a 17 ft boat weighs 68 lbs, the 17 ft boat displaces 24 more lbs of water; if the 17 ft boat weighs 40 lbs or 25 lbs, each will displace 14 lbs or 29 lbs less water).
Of the boats mentioned above, a 17 ft by 20 inch wide boat weighing 25 lbs would have less wetted surface than ANY of those other boats, and it would be faster, but here’s the news flash: if you can only sustain speeds of 2.5 mph, in a 12 ft boat, you may be able to go a few tenths of an mph faster in a narrower, longer boat (especially a lighter model), but you will not realize significantly higher sustained speed. On the other hand, If you can sustain 4.8 or 5.1 mph in a 12 ft boat, it’s time to step up to a 14 ft. If you’re looking for greater speed potential, just step up to a lighter, narrow 17 ft boat and you should be able to manage 6.0 mph before long.
