Keel or no Keel?
Seriously, if there’s any kind of …
– Last Updated: May-09-08 6:47 PM EST –
...extreme pitching, it's not the keel which is holding you. Go do that bridle line demo I suggested and report back.
By the way, back in my tandem-aluminum boat days, my skill level was pretty mediocre, and I paddled with people who's skills were atrocious. I experienced what I experienced and I saw what I saw. I still say that the person asking the question about the Old Town Stillwater, especially on the sorts of rivers he suggests (no mention of severe conditions, just some current), will find a keel to be a minor annoyance at times and nothing worse than that. He's not even using an aluminum canoe, but something with a hard and slippery fiberglass hull. I'd worry more about the keel interfering with general maneuvers and getting in trouble that way (even that's not a problem if you know a few tricks) a whole lot more than I'd worry about getting caught by it.
I'm done now.
OK , good enough …
… we’ll have to agree to disagree then if that’s OK with you … also I do not understand about the bridle line demo you speak of , don’t know what it is or what it’s about , and I’m willing to try and learn something if you want to expand on that some …
Canoe Bridle
In the days before painter attachments were drilled through the hull near the waterline, such as “tugeyes”, the standard way to line a canoe through rapids was to rig up a “bridle” (and a bridle is safer even than drilled-through attachements in really fast water). That’s just a rope that wraps from a seat or end thwart, under the hull, and back again, forming a tight loop under the boat. Right at the keel line, a painter (pulling rope) is attached to that loop. With one pulling line attached near each end of the boat, you can steer the canoe around various obstacles while standing on or near shore by adjusting the lengths of the two lines. By letting the canoe run at an angle to the current, you can “fly” it (like a kite, only horizontally instead of vertically) out farther from shore to go around rocks. With the two lines attached at the keel line, no amount of cross-current can upset the boat.
OK , I understand now …
… what you are talking about when you say “bridle” , though have never needed to “bridle” a boat … “tracking” a boat with bow and stern lines from shore is probably the exact same thing you are talking about , using the river to ferry (you called it flying like a kite) your boat upstream while on shore with ropes … also can be used to avoid some portages downstream that you would rather not run while in the boat … up stream , keep the bow farther out than the stern , down stream should be same principle except now you are backing the canoe up … if the bow swings in farther than the stern , the canoe will spin and roll … can be done with two seperate length lines or better with a single long line attached to both ends … you will always want to keep the boat pulling away from you (bow farther out than stern) , you can pull on a rope but you can not push on a rope …
That’s right, …
… and yes, the word “bridle” isn’t in such common use now, but that is the name for the setup used to attach the lines to the bottom of the hull. The method works just as you describe, except under no circumstances, even if your screw up big time, will the canoe “spin and roll”. That can only happen if the lines attach somewhere OTHER than (higher than) the bottom of the hull. The higher the attachment point, the more likely the boat will spin when crosswise to the current.
Keel
Thanks guys for all your comments. Just last week while taking a Canoe and Camping class my 15 year old son and I hit an exposed branch in such a way that quickly rolled us up the branch and swamped our boat. We were told to lean into the obstacle when that happens but it occured so fast that we didn’t have time to react. The stream was moving very fast (about 4 miles an hour) and we were in a 16 ft no keel Mohawk. I live in Southeast Louisiana and will do most of my paddling on bayous and creeks around this area so I won’t be running any kind of strong rapids dodging rocks. Next month we plan on taking a river skills class and will take my stillwater along. We’ll see what happens.
Delta kayaks have a protruding keel
how this will fare on a kayak??I think it would make it difficult to get in and out of the kayak.
Any oppinions??
Mostly agree…
I paddled a 15 ft. Grumman with keel for many years, never found that the keel caused me to get wet. Only drawback was that I needed an inch more water than I would have without a keel, and the only advantage was that the keel caught some wear that would have otherwise scratched up the canoe bottom. I paddled “shoe keel” aluminum canoes during that time, and never could see any difference in performance as far as tracking and turning ability between a Grumman with a keel and one with a shoe keel, which only protruded a quarter-inch or so.
Keels in Royalex canoes like some of the Old Towns do absolutely nothing to aid performance, in my opinion, and the fact that THEY catch a lot of wear that would otherwise be spread across the bottom is a distinct disadvantage. Their only purpose, as far as I can tell, is to stiffen the bottom of the canoe.
I hate keels …
for the most part. They always catch on rocks and trees when in shallow waters and make the boat very unstable. In big open water with a lot of wind they try to force the hull to go straight when it may be safer for the boat to move around more (i.e. roll with the waves).
So, generally you can remove a keel from a boat, but it’s easy to add one when needed. Take along a roll of duct tape and a long piece of 3/4" or larger diameter rope. If you need to cross a large boady of water and want a keel for this, tape one on. It can easily be removed when you don’t need it.
~wetzool
I’ve been reading a lot about keels. I’ve got an old (have no idea how old) Allagash 16’ fiberglass canoe with a keel that came to me secondhand and cheap - free. I’ve done a bit of fiberglass repair on it, and particularly on the keel. My wife and I enjoy river trips and now after reading about the drawbacks of keels in shallow water and rocks, I want to remove the keel. Any advice? I’m thinking I can just use a sawzall or angle grinder with a cutting disc and just remove it flush with the bottom of the canoe. Then cover the gap with fiberglass mat (2-3 layers) and epoxy. Any advice would be appreciated. We’re tired of getting hung up, particularly at my back end. I outweigh my wife by ~70 lbs.
Mostly I run rivers so I cannot stand keels. They make sideslipping and controlling boats in current much harder. Once you learn your strokes controlling a canoe without a keel is easy. I prefer noticeable rocker in addition.
Many older canoe designs had keels to join the two halves of aluminum and early fiberglass boats together. Canvas canoes often had them to protect the bottom from abrasion. Don’t drag your boat around and you don’t need a keel.
Often the fiberglass keel is molded into the boat, partly to stiffen it. If you grind it off you may be looking at your boat in two halves. Don’t do it.
I’m still a rookie at this canoe thing, but my work so far with my 15 foot Grumman confirms what you say here. The New River in southwest Virginia has been my main study laboratory so far.
Like you said, when the keel engages, it tilts the whole boat. That tilt disengages the keel, and the instant it disengages, the force of water against the hull counteracts the keel effect and re-stabilizes the canoe all by itself.
The first time I experienced this it scared me for about 5 seconds. It was a strange feeling to have the canoe stabilize itself almost instantly. I rowed back around and did it again as soon as I ran the physics of it all through my head barely enough to understand what happened.
I like the keel on my Grumman. It doesn’t hurt handling like some say, and it does help protect the hull by warning me when I’m just a touch too shallow.
The expression “On an even keel” did not come about by accident.
Primarily purpose odxa keel us for straighter tracking on lakes, if there isn’t a structural purpose. I liked a keel for that reason.
As pointed outed above, a keel makes the canoe harder to turn, reduces draft which is a problem in shallow water, and makes it harder to glide over under water obstacles. A keel would also make it difficult to slide the canoe sideways using the draw stroke.
I felt that a keel helped to reduce tipiness, but can’t prove that to be true.
We had a few aluminum canoes with what we called shoe keels. To be honest I don’t remember if was some of the alumicrafts or grummans. I just know I avoided them on river paddling trips. They seemed to like to grab rocks and leave distinct silver streaks on them. Some rocks became multi colored from red and green trippers as well as the aluminum boats.
