Kneeling
I almost always kneel for optimum boat control. It lets me shift my weight to heel the boat as needed and helps me apply a lot more power to the stroke. Admittedly, kneeling is tough on my ankles and feet which pretty much go to sleep after a half hour or so. It usually takes me a while to pry myself out of the boat at rest stops or at the end of the day. I’ll occasionally sit while paddling flatwater, but I develop tightness between my shoulder blades if I paddle sitting for more than a couple of hours. Doesn’t matter whether I’m using a straight or a bent shaft paddle.
Use knee pads when kneeling
I kneel all the time when paddling. Like others have said it improves your control of the canoe. I use knee pads (like the carpet layer use) with velcro straps. I also use a double bladed paddle, longer than most kayak paddles because you are higher off the water. This combination makes paddling easy on the back and shoulders and you can still get powerfull strokes good control. I use this method for both solo and tandem paddling.
Depends
I sit for the sake of my knees (mostly just one that is onery and pads don't help )unless the waves are up. Then I need a lower center of gravity.
Kneeling
I kneel most of the time while canoeing. I paddle both flatwater and mild moving water, my preference is for paddling small rivers and creeks. I’m not into heavy-duty WW – I’ve had all the extreme adrenaline rushes I need at this point in my life. I also canoe trip every summer up in Canada where I primarily paddle lakes and connecting rivers.
I find it interesting that there are so many different variations on kneeling as expressed at this thread. I agree with many who have posted to this thread that for maximum control of a canoe kneeling is important.
I think if I used a double blade I’d probably want to sit low and use a foot-brace and back band/canoe chair – but then again that style of paddling doesn’t appeal to me, so I don’t know from personal experience. My body might force me into that someday… meanwhile I do my “canoe dance” thing… For now I can still kneel and can use a single blade so I do.
I typically kneel with my legs spread (one knee in each chine) and my butt leaning against the edge of an angled seat. I also occasionally use a three point position similar to “sloopsailor’s” except I don’t tuck a toe under a footbrace. The one knee down/one up position is known as a “traveler’s position” in the North Country and among “style” paddlers. It allows one knee to rest (from kneeling) while allowing for a quick transition to a regular kneeling position very quickly as needed. Nice for a break.
Personally I like a nice cushy kneeling mat that gives me a pleasantly soft place for my knees, shins and ankles. I don’t like construction type knee-pads, the behind-the-knee straps cuts off my circulation. I have to wear them on occasion in my line of work and find every moment in them almost torture. But they don’t bother some folks, so to each his/her own. I also don’t like glued-in-place WW style knee pads since they limit where I can place my knees. I move my body around a lot while paddling and I need to be able to place my knees where they will help me control my boat. For instance, I often kneel with my knees in the same chine while doing Freestyle maneuvers or while cruising along Canadian style. So I prefer large mats that completely cover the floor from the thwart in front of me (in a solo canoe) to a point well behind the seat. I like a pad that reaches from rail to rail (so it won’t slide around) and several inches longer than the length of my leg (from knee to extended toe). The extra length allows me to move forward or backward as needed to pitch the canoe and allows me to move my knees from side to side for added control. ½” thick yoga mats made of closed cell foam work well for canoe kneeling mats as to “puzzle-fit” workshop floor mats (also sold as kid’s play mats at toy stores in bright colors). There are sources on the internet for closed cell foam sheets that can be covered with nylon fabric (on the top side) for added comfort – the DIY approach is probably the best option.
One of the best ready-made kneeling mats is available from Grade IV – if you can find them… they’re expensive and very heavy, but nicely made. Bell “T-Pads” are a good choice as well, but they are a bit small and can slide around. The best ready-made mat of all was the old full-size “Kneeling Bed” formerly made by Bell for FreeStyle, but sadly it is no longer manufactured. I’m indebted to my friend Clarion for locating one for me a few years ago at BMO. Thank You Brian!
BTW, I’m 57 and yes, my knees and legs get stiff after some hours of kneeling. On calm water I sometimes sit in an upright position using a foot-brace for a break, sometimes I sit cross-legged. Looking down the road (at the aging process…) I’ll kneel as long as I’m able simply because I so thoroughly enjoy the control I get while kneeling – control that simply is not possible while sitting. In short – I like to dance a bit with my canoe. – My two cents. - Randall
What Arkay said…
I’m an older paddler.
Spend about 75% of my time in a kneeling position, my butt on the forward edge of the seat, which I have lowered.
I always use a single paddle.
I use a Bell T shaped kneeeling pad in all of my boats that don’t have knee pads permanently installed.
Kneeling gives me the feeling of stability I like in my solo canoes, which I use on moving water to “play” with the river.
If I hit long, flatwater sections; I may get into a sitting position for a short period of time to stretch my legs. On occasion, I will use the one knee up & one knee down position, or sit cross legged for awhile.
But, bottom line, I like the kneeling position on all classes of water.
Sittin makes my back hurt & I don’t like seatbacks.
BOB
I also switch between kneeling and
sitting. I have two of my three canoes setup with pads for kneeling. My 18 ft tripper has a tractor seat so kneeling isn’t practical on that canoe, but the seat is low and I use the foot braces to keep myself wedged firmly in the canoe in a chop. Kneeling will lower your center of gravity and give you a steady purchase in the canoe when you need it for paddling in wind and waves. It also gives you a change of position when your but goes numb. Even though I’m not a WW paddler, on moving water you still need to do eddy turns, and on lakes, it’s not always calm. Even if you only paddle on lakes, one time or another you will get caught in wind and waves. When that happens, you better have a way of keeping yourself glued in the canoe.
Try using a saddle
When paddling my 15 foot canoe solo, I will place a a peice closed cell foam (cut from camping pad) in the bottom closer to the center of the canoe to kneel on. I have also taken a couple of these old camping pads rolled them up and stradle the roll like a saddle, helping take pressue off the knees.
kneeling pros and cons
Thanks all of you for the thoughtful responses on kneeling. It’s so interesting to be able to get clued in on everyone’s personal styles and problem solving techniques! What a great forum!
kneeling or sitting?
Most people who say they are kneeling are in fact sitting with their knees braced against the hull under their seats... If they really had to kneel, they wouldn't like it for more than a very short time. I know only a few people who really kneel for a long time. In fact I know few people who really kneel for short moments too (including myself). I myself do it only for very short moments, when 'FreeStyling' and when paddling tandem in a touring canoe a rapid; when I position myself more forward (just behind the stern thwart) to get a better trim for paddling backwards. BUT, people I know who say they prefer kneeling, never kneel that way -- at all. Kneeling (or semi-kneeling) is easier on the back because a good paddling position comes more natural, and balancing the canoe while making a paddle stroke is easier. When paddling sitting, back problems can indeed be a problem, especially with a low seating position. But often this is for a large part because the body posture is bad, the knees are too high, the feet are not braced (well), the leg muscles are too short, and last but not least the lower body (stomach) muscles are too weak (doing sit-ups every day is a must!).
Contrary to what a lot of people think, sitting is a more powerful position for paddling forward hard for a long time. That is why marathon and (most) downriver open canoeists and kayakers paddle sitting! If kneeling was a stronger paddling position, racers sure would kneel, even the kayakers! Sprint canoeists do kneel, but only on one leg. Their other leg is extended forward with the feet firmly braced. Practically, this can be seen as a very similar position as sitting (on one leg), only then very high. Which indeed is the strongest position for paddling forward (except for standing) but also the most unstable and, in the long run, very tiring. For the back perhaps paddling standing, as so many 'primitive' paddlers do, is the best...
knee hooks?
Neversaw them. Do you have any pictures, a link or a description. Can’t pass on a potential way to connect with the boat without asking the question. thanks.
Kneeling, kneeling and sitting
Yeah but kneeling, putting my weight roughly equally on my knees and my rear end which is either on a saddle or the front of a seat, gives the best boat control.
While both marathon and downriver racers sit, whitewater slalom canoe racers kneel.
For some reason I have the idea that in whitewater slalom, C1 racers (kneeling) have faster times than kayak racers (sitting). Anybody care to confirm or deny?
Edit: It appears that I am wrong and the slalom kayaks are generaly faster. DOH!
Tommy
Some clarification
I never thought there’d be such nit-picking about the definition of the word “kneel” as Dirk brought up. But hey, we’re having a discussion, so let’s get right down to the finer points.
I don’t know anybody who paddles for any length of time while kneeling with all their weight on their knees. This would be extremely tiring and not very stabile.
I wrote earlier (as did others) many canoeists who “kneel” are indeed taking a three-point stance: knees in the chines with their butt leaning against the front edge of the seat. In FreeStyle we routinely shift from this 3-point position to “true” kneeling (butt unsupported) as part of weight shifting used in a wide variety of FreeStyle maneuvers. Typically when we kneel for one of these maneuvers we place both knees in one chine as we lift our butts up. This transfers weight from the centerline of the canoe forward. This forward weight shift causes the bow of the boat to pitch forward slightly while at the same time raising the stern partially (or sometimes completely) out of the water. This weight shift is coupled with a strong heel to one side (that’s why we place both knees in one chine). These body/weight shifts combine with an initiation stroke (used to set-up a spin) and a static paddle placement to make our canoe go into a spin.
WW canoeists also don’t “kneel” (butt unsupported) strictly speaking. Instead they partially support themselves with their foam pedestal – between their legs.
Canadian “Style” paddlers also don’t “kneel” (again, butt unsupported). They sit on their legs or on a bean bag or other small bag to take the train off their leg muscles. Style paddlers sit this way in one chine.
Native people also did not “kneel” strictly speaking. Typically they sat on their legs and as needed kneeled against a thwart in a 3-point position. They also stood up and poled as needed. It should be noted that there is no evidence anywhere that shows native bark canoes even had seats, in fact they did not. A seat in a canoe is a thoroughly modern invention. Seats did not appear in Eastern North American canoes until the later part of the 19th Century. They were added sometime during the transition period between bark canoes and cedar canvas canoes. Seats are a “white guy” thing.
As to sitting versus 3-point kneeling for flatwater racing, sitting in various positions, but usually with a foot-brace (another modern invention) is used in flatwater racing. Power can be transferred most effectively from the paddler to the water in this position. It’s not as stabile as 3-point kneeling by any stretch of the imagination, but it does work well for flatwater racing.
Standing in a canoe like one does while poling is probably the most powerful position of all. However, few would ague that it’s a stabile position. Well, maybe a Duckhead or two might… but then again they’re Duckheads… ;^)
To sum up - kneeling in 3-point position is extremely stabile, more stabile than sitting. I’ll just continue to call this kneeling and not bother to quantify the “3-point” bit – that should go without saying…
Make that 4 cents worth this time around… - Randall
Whitewater slalom kneeling
Tommy asked:
a slalom kayak is a little less maneuverable because of the
extended legs, but nevertheless still a bit faster (about 3%?)
because of the double bladed paddle technique.
A slalom C2 is faster though
Indeed, for the sake of the discussion about this subject, I find it necessary to make the advocates of kneeling realize that what they do, could be viewed in another way. Especially because most of them never do kneel without a seat… But normally, I just would call it kneeling too.
Point is that some people get scared about sitting, when such a kneeler advocate insists that kneeling is the best way to paddle a canoe.
a stupid question
This may be obvious to some but as a kayaker and recently paddling a solo canoe I have found the most effective forward stroke with a double blade paddle is when seated in the canoe and using the footbrace to power off for the rotation. When I have tried to use the double blade paddle in rough water in a kneeling position I can’t get the same power from my legs to power the stroke.
For those that use double blades on occasion, how would I use the kneeling position for power? Even the sit and switch with a bent shaft canoe paddle would require a seated position to be effective?
Kneeling
In rough conditions is the way to go. It eliminates one step before praying.
Andy
AMEN!
Can I get a Halelujia!
Brother Tommy on my knees
Indeed
Kneeling as practiced by many canoeists is a three point position; 1 butt, two knees. In my case I usually lean against the seat – I not only realize what I do when I say I’m “kneeling” I’ve also included the 3-point description in each of the three posts I’ve made to this thread – so that others understand exactly what I’m saying. I think most people get it, if not perhaps they need to work on reading for comprehension. Let’s move on now. - Randall
Power from the torso
Kneeling in my flatwater boats I have on occasion found myself powering right off the seat.
I guess if I had to I could rig thigh straps and or knee cups like in my whitewater boats.
Seriously though I think kneeling is for control.
Sitting with a footbrace might work better for raw power.
Tommy
Make them so they extend from the sides
of the boat, from just below the gunwale. Often you can use Minicell. They do not usually need to be like kayak thigh hooks, but if you have something to brace your feet against, then your thighs will catch effectively even under partial thigh hooks.
