I just bought a Honda 2.3 motor for my 17’ aluminiun Grumann square stern canoe. It weighs 27 lbs empty and has a quart/liter gas tank on the motor. Haven’t figured out the gas mileage yet but it seems to run quite a while on a tank of gas. It runs at a pretty good speed with my wife and I in it and can run at trolling motor speeds. While it is not real loud,it is not as quiet as I would like it to be going slow. I need to take it out with my GPS to see how fast it can go and what the gas mileage is. When I find out I will come back and post it here.
gas i bought a pelican canoe in the spring for fishing along banks near the landings. i was gonna paddle for exercise. caught in a wind one day that caused more exercise than i wanted as a heart patient, i went with the minn kota. now i needed a transom, insurance, registration, battery but it was worth it. if…my transom wasn’t off the side of the boat causing balance problems, i’d take the 2 horse any day. my day is limited due to battery power. the small motors have self contained fuel for about 30 miles. to carry a small amount makes for twice that and a little quicker. if i find a good one light enough and good enough i’ll go with one.
Registering electric In the last few years (maybe 06 or 08) TN changed it where like NC any motor and you have to register. Prior to that electric didn’t require registration.
Trolling with gas 4 stroke motors idle well enough that I can say there is nothing wrong with trolling at idle with them.
I wouldn’t reccomend trolling at idle with a 2 stroke, they dont idle as well and the gas oil mix likes to foul spark plugs if they stall on you, then you are looking at paddling back unless you have your tools on you.
ELE vs Gas HP an electric with a like 2.5-3 hp rating is gonna have like 50-60 lbs of thrust a 2.5-3 hp gas is gonna have like 75-80 lbs of thrust because they are rated in a different manner, but lbs of thrust is the more accurate way to compare engines because lbs of thrust arent rated different on one vs the other.
Also a large electric has a prop pitched for moving a MUCH larger boat at trolling speeds rather than moving a tiny boat at a reasonable speed.
keeping a battery in good shape There are little battery conditioners that keep a 12 volt battery charged up for only a few dollars at Harbor Freight and other stores. I have kept a used battery on one for over a year and it was ready to go when I needed it. It does not charge a battery, but keeps a trickle of electricity on it to compensate for losses and it works.
Modern two-stokes do quite well Actually, Mercury two-stroke outboards way back in the 70s could be used for trolling at idle all day long with no problems whatsoever, and I suspect Johnson/Evinrude were the same but I didn’t hear much about people trolling with them. I guess by “modern” two-stroke motors, I’m referring to everything but the primitive old models that burned 25:1 mixtures. The “really modern” ones of today with electronically controlled oil proportioning should be even better. I would still expect four-stroke motors to be the best for trolling, even though the days of two-stroke motors performing poorly after long periods of idle have been gone for a long time.
Yes. If the two people have narrow enough backsides to fit, and if the two people have a clue about needing to keep their combined center of gravity over the center line of the boat, then they could fit. You would not be able to fit two large Bubbas on one of the center seats.
The boat’s initial stability is good. Standing to paddle, scope, cast, spot fish, etc. is no problem. I have even been able to stand and motor with the boat using an extension handle. Further, unlike a lot of other squarebacks, the Cargo actually has some secondary stability. The water I paddle doesn’t require my to get into the secondary stability, but it handles mild rapids quite nicely. I think the most I’ve done with it is a straight ahead class 2 shoals type rapid that’s about 200 yards long. I row the canoe rather than paddle it through things like that. I like being able to brace on either or both sides if necessary. Thus far, it hasn’t been necessary.
2 person are 2 girls weight about 50/52 kg and height about 1.65./1.70 : I think the backsides are quite ok for this duty.
Let me ask you another question : it is possible to carry the Cargo by one man? or the canoe is hard to carry for a one-man only, from a top of a machine to the shore of a lake 200 meters away ?
It’s quite heavy. I use wheels. I can load and unload the boat from my truck, but for moving it I use wheels. I would never want to do an overhead portage with an Esquif, and certainly not alone.
For loading, I pick up the stern of the boat and swivel it up onto the tailgate extender of the truck. Then I go to the front and pick it up and slide the boat into the bed. To unload, I do the reverse. When I had a roof rack on my old truck instead of a tailgate extender, I did a similar maneuver, but that required me to bend over underneath the boat and use my back and legs for most fo the lifting, then a shoulder press to push and slide. With practice, it was fairly simple, and I was usually able to do it more easily by myself than with assistance. It helps that I’m a bit ‘bulky’ of an individual, and a little taller than average.
For moving, I have a set of wheels that I put under the stern. Then I only have to lift the front and pull the rest of the boat along.
I find this to be a convenient way to “carry” the boat, because with the wheels, I can put the paddles, PFD’s, the days lunch, some fishing tackle, and what-have-you into the boat. I put the motor on the transom or if trolling motor I put the battery over the axle of the wheels. Then with the wheels its comparatively easy to wheel the boat and contents to the launch. This method doesn’t work very well at primitive launches, though I’m sure with some ingenuity it would all work out.
I bought a Wenonah backwater canoe for fishing small lakes http://www.youtube.com/watch?v=DRexgdLjHEk.
I went back and forth about gas motor or electric.
I went with the traxxis 55 electric motor and a 70LB 105 amp hr battery.
My son sat in front-He weighs 320 lbs-I weigh 213 plus the 70 lb battery and the trolling motor.
It was pretty good for the first few runs on the highest setting but you could tell it slows a little and then you have to charge the battery right away when you go home. Running the battery down to 10 volts can really hurt it. I didn't care for it-even though it was pretty good but I looked and looked and bought the 2.5 Suzuki outboard and let me tell you.
Super quiet and much,much faster and more power.
This is for me-I loved it and so did my son-Now he wants to go to the adirondacks.
Do yourself a favor and get the gas engine. about 60LBs lighter than the electric setup.
dfg4240
power and speed exactly the answer i was looking for. I have a flat back canoe with and electric motor and it is just too slow for my tastes. Planning a 2 or 2.5 gas engine
GAS Electric motors don’t have the power and torque of gas and require big heavy batteries which when dead leave you stranded. A 3.5 tohatsu 4 stroke gets 45 mpg and will drive my 14.5 foot sol skiff at 12 mph. There is no electric that gets that kind of performance. An extra gallon or two of gas onboard and your good for a whole weekend.
