DID JUST THAT WITH THE S-PRO
when we did a night paddle -boat was an eerie glow-in-the-dark almost lime light green.
When I went to the 4th Annual South Florida Multiclub Picnic at Ft Myers last month, there was a fellow there that had his yak outfitted with the full running lights setup, fore & aft, port & starboard, and semi-aloft on a short staff, all rigged to an under-deck battery. Serious stuff…
But it’s always a good idea, at night, to carry a waterproof flashlight you can use in hand to see, as well as a light that lights your boat so others can see YOU. When you paddle the mangroves and mangrove trails, in the dark, sometimes there’ll be a wayward brach, or a spiderweb or whatever, that the flash downstream every so often can help you avoid as you
Paddle On!
-Frank in Miami
In the live free or die state of NH
you need a 360 degree white light. Lots of folks use a c-light on the deck in a suction cup holder and a headlamp to make up for the dead zone of the paddlers shadow. I have no idea whether this really meets the requirements. Scott B, raddog and other NH denizen would know.
YEAH-I KNOW -BUT WHEN I’M IN A CHANNEL
like the cross-Key largo waterway, I’ll turn it on anyway just to let the boats coming up from behind know I’m there… The ones coming towards me I can relatively easily work to avoid -Don’t like the idea of one of them coming up behind me, even in a relatively lit place like that, especially if there’s an oncoming boat and all of us cross paths at the same time.
Irrational fear of getting pushed into the channel wall or getting that run-down feeling I guess… I think that, besides the various flash patterns, there’s a steady light option as well.
Just want to be seen enough so I’m still around to
Paddle On!
-Frank in Miami
Yeah - no kayak lane! NM
Problems with flashlights
The problems with flashlights/lanterns (no matter how bright) for on water visibility:
You have to already know a boat is closing with you
You then have to get it, turn it on, and shine it at the boat.
Meanwhile you had to take a hand off your paddle, and stop paddling to use it.
As a result you lose ability to maneuver. Sitting in one spot or drifting may be exactly what you do NOT want to do.
Most have limited burn time.
Truly powerful ones are heavy and large.
Flashlights may “work on a pond” - but does not add up to a good visibility plan for night paddling with other boat traffic. Read the link to the article above. Real tests, real boats.
By the time you get your flashlight out - and get the other boat’s attention - you could have more easily just paddled out of the way in most situations. IMO that would be safer/smarter than staying put and frantically waving a flashlight around and expecting the other boat to do ALL the maneuvering (assuming they see you).
If you have the time to get out a flashlight and get someone’s attention with it - how much danger were you really in anyway?
Do of course carry a good flashlight anyway. Lot’s of things they are good for…
Light mounting
There are various options. Many boating supply sites offer them. Your needs are simple. A bright 360 degree white light in a fixed position on deck. Old Town has a fishing pole/light type mounting system for their rod holder/light mast configuration. Worked well on my Sons boat. Tons of lighting options out there. The internet is great for “yahooing” and finding things.
Please avoid the suggestions of shining a bright flashlight AT the oncoming vessel. Your required to have a light burning already. Not break one out and wave it or target it at the approaching vessel.
Please avoid other suggestions such as “glowsticks” or illuminating the interior of your boat… You simply need a white light that shines from all angles, preferably a tad elevated since we sit so low on the water.
Your in a small manueverable craft too so you will generally have a good advantage of moving out of the way should you not be seen.
Have fun!
Lights
I have a headlight I got from good old Wal-Mart that has either a single red LED or 2 white focused LED’s (Energizer - $12.77). It isn’t waterproof but hopefully I won’t be paddling in conditions at night that will have me needing to roll.
I also have a very bright 4 focused LED flashlight that I use to signal boats that are approaching(all that is legally required). If I am paddling in an area that has a lot of powerboat traffic I also use red green and white lights that I also bought at Wal-Mart. They are really cool LED “Glow Sticks”. They are much brighter than chemical glow sticks and they last much longer as well. the best part about them is that they are also actually cheaper at $2.48 each! I stick the red and green under my deck rigging like Grayak does and I stick the white one in the strap of my headlight in the back.
Just a 360* white light would indicate to other boats that you are a vessel at anchor. That could possibly be dangerous if someone saw you and assumed you were at rest and then suddenly saw you again in another spot. Perhaps that is why the law is the way it is?
In my state and many others the comment, “Please avoid the suggestions of shining a bright flashlight AT the oncoming vessel. Your required to have a light burning already. Not break one out and wave it or target it at the approaching vessel.” is the opposite of the truth.
db
Thanks for the correction!
On the light. I must have been thinking of anchoring!
Links
I dug up some links on the lights I mentioned. You can get them at Wal-Mart.
The “Glow Stick” type lights are here($2.48):
http://www.garritylites.com/site/retail_details.php?recid=87
I’ve been told by other boaters that they were very visable.
This is the very handy headlight I use now($12.77). I used to be a Tika fan until I found this:
http://www.energizer.com/products/flashlights/flashlight.asp?cat=4&id=3
This is an AWESOME camping light ($12.77)
http://www.energizer.com/products/flashlights/flashlight.asp?cat=1&id=2
Kayak Lights
Have’t read all the posts here but have read this topic numerous times before on other boards. DON’T GET CREATIVE. Follow the USCG regulations. Running lights have specific meaning, e.g. yellow strobe - indicates a hovercraft etc. Many years ago on my Masters unlimited exam I had to idenify what lights a mine sweeper displayed, sweeping for mines at night on a Western River.
There are three distinct set of rules and regulations for International Waters, Inland Waters and Western Rivers (not necessarily in the western U.S.). Again, follow the USCG regulations.
Please read this
I know I’m beating a dead horse, but some of the suggestions here are just not good. This explains why:
http://home.earthlink.net/~taterka/LightMemo.html
I realize for many it doesn’t matter. They have little boat traffic, etc. Even more reason to not suggest light sticks or wrong colors to those who may.
Please - if you haven’t - read it. Too lazy to click the link? OK here’s the whole thing:
Human Powered Boat Group
LIGHTS TESTING
Subject: Results of Lighting Test for Paddlers/Rowers
Date: June 14, 2001
As we were finishing up our testing of a number of flashlight systems that would make paddlers and rowers most visible in NY Harbor, Jim Wetteroth of the Downtown Boathouse came up to me and said “The Coast Guard was right all along.” What he was referring to was the standard lighting requirement for small vessels such as outboard motor boats, i.e. a red/green combo light at the bow and an 360 degree white light up on a stem toward the stern. Jim went on to say, “The more we look like other boats, the more we will be recognized as one by other things out there.” And he is right based on what we were able to see.
The red/green running light concept gets rid of one of the problem facing an urban paddler at night: How to avoid his/her white light being lost in the confusion of bright lights of a city?
***The US Coast Guard requirement that small human-powered vessels have a white light ready to turn on when approached by oncoming traffic is totally inadequate except on some small lake somewhere.***
Paddlers in the Big Apple know this and have been using different lighting schemes that have at their base some light that is steadily on and not meant to be intermittently shined for approaching traffic.
The task of the Human Powered Boating Group (HPBG) was to size up what lighting systems seemed to work the best. Earlier there had been discussions of having some special color of flashing light set up here in NYC harbor for use by paddlers. There were problems with the idea. Finding a light color that was distinctive; lots of flashing lights are already taken and have a special purpose such as a flashing blue one for law enforcement boats. Strobe white lights are out since they are, in effect, emergency beacons for some one in distress possibly in the water already. Every vessel spotting a strobe is legally and morally obliged to stop what it is doing and come to the aid of those sending off the strobe distress signal or to radio an alert to the Coast Guard. If they don’t, the penalties are severe including loss of captain’s license, fines, jail time. Flashing lights are taken that seriously. It might be possible to designate some flashing color for paddlers and agree to this in the harbor, but what about visitors; would they be confused and come to the aid of a flashing light? Or would flashing lights be confused with navigational aid lights warning of obstacles in the water and along the shore? Maybe it will happen some day but the wheels of regulatory change, especially ones that go against well-known habits and protocols, grind too slowly to wait.
So the HPBG decided to operate within existing parameters and existing light schemes. We tested seven different systems or variations of systems last night. The systems were on different kayaks operating within the Downtown Boathouse embayment and its immediate outer edge bordering the river proper. To check their effectiveness, the kayaks were viewed from the DTBH pier looking outward to the river and from a small motorboat out on the river looking back. This allowed us to test them against both city lights and more open water. The kayaks moved back and forth (like shooting gallery ducks :-)) so we could see them from both sides. They also came at the Pier and out toward the motorboat to see them from the front and from the back. As an added test, the kayaks moved along the dark background of the derelict Pier 32. Here are the results:
A) First of all, what DOESN’T work:
- Headlamps. Our finding from both the pier and the motorboat underscores what the NY Waterways ferry captain advised us about last week from his viewpoint high up on the bridge of his vessel; “Those miner lamps don’t work. I can’t always see them as the guy’s head bobs up and down or he turns his head. They aren’t steady enough and I just don’t really see them.” Amen. Headlamps with a straight focus beam were visible only now and then. They may be great for spotting your campsite after a moonlight cruise out in the wilds but they are not good as navigation lights to make you visible in city waters.
- Headlamps with red/green lens. To my knowledge these don’t exist but did seem a good idea to try. To test this, Jim Wetteroth tried an experiment of jury-rigging a red/green light to a headlamp. It also proved as useless as a focused white headlamp. Any movement of the head throws its port/starboard indications off. A headlamp would only work in one configuration explained further down.
- Chemsticks or chemlights. Many paddlers believe these work because they crack the vial, shake it and it seems to give lots of light. Another paddler 50 feet away who has one seems to be visible. But it is an illusion brought on by closeness. At any distance they don’t show up at all. We saw that on a kayak in the embayment not all that far from the pier.
- Anything with AAA battery power. We didn’t test this last night, but such a lighting system, from past observation, is minimally visible. More importantly, AAA flashlights with cones such as from Princeton-Tec, die in a little over an hour of constant use. At most consider these as a bare minimum just-in-case light if you get caught out at the end of the day in encroaching darkness. If you have such a light, you may want to upgrade your just-in-case system now to the AA version for more power and longer burning time.
B) What DOES seem to work:
The best system seems to be the following: First, have a red/green light system on you bow deck in front of you no farther than you can reach to turn on and off or replace batteries if you have to. Next have a white light with cone high on your head, connected to a headband or to the back of baseball cap. Lastly, have a cone white light behind you on your stern deck, raised a bit if possible.
This system has a lot of advantages. It gives you that red/green configuration that makes you definitely identifiable as a boat to others on the water. By having the cone light high on your head, you have a constant 360-degree white light showing. The cone light on your rear deck sets a pattern of two white lights in conjunction with the cone light on your head. The more there is a pattern, whatever it is, of a series of white lights, the more they stand out.
Some of us, including me, have questioned the use of red/green lights. Our concern is based on not wanting to be confused by the captain of a large vessel with small motorboats that can move a lot faster than paddlers or rowers. However, small motorboats are often moving slowly or even in a trolling mode, i.e. not faster than a kayak. So, I don’t think a large vessel captain would necessarily expect that a red/green bow light meant 30-knot speed. And, the benefit of being considered a boat is of utmost importance to us in the long run.
You can achieve this lighting combination for as little as $50 retail (not counting batteries) using incandescent bulbs with better versions of this using LED lights going up to over twice as much as that as an initial cost. Neither is a lot and anything less won’t get you really noticed at night as a boat.
- The less expensive version of this involves the following.
A split red/greens 4 AA light from West Marine that runs $19.99. Look for the version to put on inflatables. It will require some playing around with it to fit under bungees, possibly creating or buying a plate to put it on; or just use foam. It has the advantage of lots of power, brightness, a degree of waterproofness and it will float.
For the cone lights use either Princeton-Tec models or the Mark III from Tek-Tite (these cone lights retail for around $13 to $15 each. For full effectiveness the Princeton-Tec models require some doctoring. The normal cone light powered by 2 AA batteries and sold as the Aqua Flare lacks slots through which to attach a Velcro or other type strap to secure it to your headband or hat. What I have done is to buy the Princeton-Tec Aqua Flash, which does have those slots, and swapped out the flashing light bulb. In contrast, the Tek-Tite Mark III already has the slots for straps, runs on 3 AA batteries for greater brightness and longer burning time. The cones for the two brands differ. The Tek-Tite Mark III is taller and clear with a white plastic strip inside that reflects the light coming up from the bulb. The Princeton cones are shorter but broader and translucent. I think the edge might be with the Tek-Tite cone as, being taller, it stands up higher.
- The more expensive version involves the following:
For the cone lights, put in LED light modules, preferably a 2 or 4 LED light one. Such modules cost around $20 but they have the advantage of staying brighter for longer and having much greater burning time with your batteries than do incandescent bulbs. LEDs ordinarily have a disadvantage in that their beam does not project far, BUT this doesn’t matter in a cone light when all it is doing is lighting the cone up or reflecting across a plastic strip in the cone. So there is absolutely no disadvantage of LEDs in cones.
I am not certain if Princeton-Tec has a provision for this but Tek-Tite does. You actually buy the basic cone light with either 2 LED or 4 LED. The models are called Mark III 2 LED ($34.95 suggested retail price) and Mark III 4 LED ($44.95 suggested price). The Tek-Tite has an advantage in that it is based on a 3-cell battery system, the ideal one for LED lights. In a 2-cell battery system you will get less power out of an LED (a 4-cell system is too much and you have to have a 3-cell with one dummy cell to operate a LED). BTW, the 4 LED is noticeably brighter than the 2 LED.
The only LED green/red system on the market is a product from Tek-Tite called the Navlite. It has two Mark III bodies, one with red cone, the other with a green one placed in a special pouch that has a grommet and other ways of tying to deck D-rings and bungees. It sells for $55.95 with a 2 LED bulb in each. Its advantages over the incandescent West Marine basic split green/red light are greater waterproofness (really submersible) and longer battery life and continued brightness as well as being unbreakable and bulb life measured in the many thousands of hours. The disadvantage is the initial cost outlay.
C) Other Lighting Systems and Thoughts:
- One system that did not have a split green/red light component but that worked extra well was one we cooked up based on the Princeton-Tec Solo Headlamp. We placed a Princeton-Tec cone over the light, giving the paddler (Jim B., a good sport) a silly Unicorn look. At the back of the headband we strapped a Tek-Tite Mark III 4 LED. Two cone lights so high up on the head made the setup quite visible. Plus, it created a pattern of lights that was constant and being so close together seemed to give them even greater visibility. If you can stand having two lights on your head, you will have a distinct visibility advantage.
- Deck lights do help give you more of a distinct profile. This is especially true if you can pre-arrange a light at the very end of the bow and the stern as well as have some on your head or PFD. Just an added note here: If you plan to use a red/green light navigation on the bow deck in front of you, dispense with a white light way up at the bow end. It confuses and diffuses things.
- Cheaper lights do show up nicely. There is a cheap Everready yellow light that retails for under $10 in places like EMS. It really doesn’t have a cone but rather a raised glass portion. These show pretty nicely. The problem with them is they are not that well made and can fail. They also don’t have much burn time.
- Anything at the back of your PFD, unless high up on the shoulder, is very limited in how much it can be seen. But, again, it is something that can fool you as you may see another paddler in your group and believe he would be visible from far away when he isn’t.
- Deck color helps in being seen. Lighter colors reflect back deck lights and even lights on your head to a degree.
D) Sources For Lights:
Princeton-Tec’s are ubiquitous although you won’t always find the Aqua Flare or the Aqua Flash, with its better body because of the strap slots. Try a dive shop since both lights are big with divers. A good one, with good prices, is Leisure-Pro on West 18th St in Manhattan. Leisure-Pro would also be a good source for the Tek-Tites, although the Mark III LED versions do not appear in the catalog or website. Call them and say that Tek-Tite has these other lights (and the Navlite setup), state the list price and they will likely discount by a nice percentage. You can also purchase direct from Tek Tite.
E) Thank You’s:
The test was under the auspices of the Human-Powered Boating Group. We used the Downtown Boathouse and volunteers. I would like to thank Jim W. and Tom for manning the motor boat and make observations from there. Also to thank Andrew for helping me on the pier. Bonnie, from the Manhattan Kayak Company and co-chair of the HPBG, who acted as field general on the water. And to volunteers, Richard, Scott, Harry, Jim and Susan.
For more info on the NY Harbor Human Powered Boat Group, contact Ralph Diaz, Chair, Human-Powered Boating Group
Loaded for Bear, Tri-athletes, etc.
Great thread.
I paddled in right at dark last night on a small lake that allows no motorized boats. I had my headlamp but had forgotten the requirement for the 360 white light here in TX. My bad. I’m going to get one asap.
I used to use an old two mantle Coleman white gas lantern set up with a homemade mount on my old canoe. Overkill and not too handy these days I guess. It did light up a river though and many an interesting critter too.
Speaking of hard to see: Tri-athletes use this little lake to train for distance swimming. It turns the hazard issue around. These swimmers are the lake users who are difficult to see and my solo canoe and the numerous kayaks that use the lake are the potential hazards. Keep you very alert, when in the part of the lake they frequent.
Osprey
You wouldn’t by chance have been paddling Boerne Lake would you?
Osprey
I see lot of triatheletes in the lake
where I paddle. Lots of power boaters too. The sane swimmers tow an orange floating ball.
Yes
That’s right, Boerne. I’ve only been out there a half dozen times now maybe but am growing fond of it.
This is the third time I have read this
and I finally realized that these folks just might know more than me, Especially ralph diaz. This goes to show that there is hope for us all.
I think I’ll throw down for some navlites.
Thanks!
solar yard lights
(wow ... another thread about night lights!) : ()
If you don't mind adapting them ..
Is what I am going to do sooner or later.
(adapt solar yard lights)
You can buy them in sets of 8 for like $25 ...
I plan on using two ... one on each hatch lid.
(front and back)
.. attached with velcro to each hatch lid ... and secured with a bungee run over the top to the deck rigging on each side.
(so they stay with you if the velcro comes loose)
So you can quick remove them ... but they are secured two ways ... (velcro and bungee)
Then ... make a shield (90 degree?) for each light so it doesn't shine in my face and mess up my night vision.
So I'll have one in front and one in back ... at least one will be visible from anywhere .. both will be visible from a large area ...
.. they will both be white ... or you could even do a bi-color shade for red/green on the front and satisfy the safety Nazis.
... but all thats necessary by law in MOST states on a small unpowered boat is a white light.
Visible for at least a half mile.
Waterproof
Cheap
Orig batt's last 2 years
Attach to your deck/porch when not using on the boat.
Other than those ... I usually run a red flashing bicycle light on my hat ... very bright.
I turn the hat in whatever direction I hear trouble coming from .
... and usually stick to 500 feet from shore.
Navigation Lights
The Federal Inland Navigation Rules require that “vessels under oars” have a white flare up light (a flashlight) to be shown upon the approach of another vessel in sufficient time to prevent collision.
Optionally, vessels under oars can show the same lights as a sailing vessel under sail, e.g. a red side light on the port side and a green on the starboard or a combination lantern on the bow and a white stern light. The side lights must each show through an arc of visibility 112 1/2 degrees from right ahead to 22 1/2 degrees abaft of beam while the stern light must show through an arc of visibility 135 degrees 66 1/2 degrees on either side of dead astern.
States may have their own requirements that exceed the Federal requirements or if there is no Federal jurisdiction. Check with your State Boating Law Administrator.
Personally, I go with a good flashlight at night.
Bosn
Night Vision
I just wanted to slightly correct and update my post. Our color vision comes from the cones in the eye as I described. Since most light at night is blue we want to protect the blue cones by using red light.
Far more sensitive are the rods in the eye which are much more sensitive than the cones. They do not provide color vision. They are also much more sensative to blue light so once again, always use red light to protect the sensativity of your vision.
It is also helpful to make certain you have the best eyeglass prescription at night.
