@Photecs said:
@JackL thanks, I totally agree.
@Yanoer & @String, how tall are you guys?
My other issue I seem to be fighting with… high bs low style paddle. There will be times I want to power down and go, there will be times I’ll want to sit back and slow paddle… I’m 6’1”, 210. Is there a good “middle ground” paddle that’s a mix of both styles?
I’m 6’2", 225 lbs, muscular build. I started out with the 230 that came with my first boat, which has a 23" beam. It was way too long. I shortened it myself to 215, then broke it attempting a new self-rescue technique. I then ordered both a replacement shaft for that paddle, plus another paddle of the same type. Both were 215.
One of my paddles is a Nimbus Kiska with carbon fibre shaft and fibreglass blades. The other is also a Numbus Kiska with the same shaft but Carbon/Basalt blades. They both weigh very similarly, despite the carbon/basalt supposedly being lighter.
Check out Nimbus paddles from BC. Small Canadian company, decent product, good prices. It’s perhaps been a few years now, but I was able to speak directly to the owner for a while when I called. Nice chat.
Your problem in selecting a paddle is that you don’t have enough experience with … well, anything. That’s quite normal, and there’s nothing you can do about it except what you’re doing. You’re trying to pull from other people’s experiences in lieu of having your own. But eventually (sooner, rather than later) you’re going to have to make some difficult decisions on what to get. Your decision will probably be pretty good, but you need to embrace the fact that your decision can NEVER be absolutely guaranteed to be the best. A well educated decision is the BEST you can ask for. In all likelihood you’re going to be “tickled pink” with your new purchase because it’s so much better than what you’re using. If you find that after a while there are better things out there that you can afford and would like to have, then go for it. That’s life. Don’t be a victim of “paralysis by over-analysis”.
As for high vs. low angle, I’m guessing that unless you’re planning to spend most of your time “lilly-dipping”, a high angle paddle - or something closer to high angle will probably suit you better, at least in the short term. Both types can be used for both styles, but the matter of efficiency comes into play due to how much of the paddle is in the water and when. I think far too much attention is given to this BS of high vs. low angle paddling, quite frankly. I don’t even know whether my Nimbus Kiska is high or low angle, nor do I really care. I do know that it has suited me very well, despite my coming by it completely by accident
I also use a Greenland Paddle at least 50% of the time. I like it in the winter when I have to punch through some ice to get where I want to go.
