I purchased a 1947 Grumman, square back, 17’ with a 3.5 hp Scott Atwater motor. Garage find in great shape. Canoe has what looks like a Teak wood frame on the bottom.
3 questions:
what is the best method to bring the aluminum back to life ?
value of your canoe` I’m just underway trying to do the same thing. Mine is likely one of the 1st Grummans ever made because my great uncle was V.P. @ Grumman during WW2.
What’s your serial #? How are you sure it’s a 1947?
Bring Aluminum back to life? Not sure what you mean by bring Aluminum back to life but Mothers Mag and Aluminum polish will make the aluminum have a mirror finish shine for a little while you might need to wax it afterwards otherwise it will oxidize again. Mother’s can be found at most auto parts stores.
I’ve seen a couple aluminum canoes… …shined “back to life”. Don’t do it. Better to keep it dull and subdued, and it will eventually lose it’s shine again anyway. It’s a lot of work for nothing, and if you get carried away it can make the boat look bad. In the best of cases, the shine is annoying.
