VIDEO: sea kayak sailing
Kayak Sailing
If you are afraid to kayak sail because there will be a asterisk next to your resume item, for your macho kayaking achievement, you should consider swimming your next adventure. :slight_smile:
You can go further and faster with a sail. Us kayak sailors usually go further and faster than our paddle only kayaking friends. Its not to prove anything. It is because we are having a blast. Even though we are faster we are almost always the last ones off the water. We just do not want the day to end.
Really kayak sailing is a skill that is above and beyond kayaking. It requires sailing knowledge, more advanced decision making skills, paddling skills way beyond what is necessary for normal paddling.
A beginner paddler can kayak sail, but it requires reducing the conditions they are willing to go out in. Eventually kayak sailors are so drawn to windy days, that their paddling skills grow way beyond where they where before they paddle sail.
Here is s video of a sail some friends and I did last week end.
http://www.youtube.com/watch?v=ysVTtX4H8B0
It is not smartly edited like ND’s is and it is not tropical either. In any case, we had absolute blast.
One girl in our group went for her very first paddle sail. I knew she was a very good paddler so I let here use one of my boats and rigs.
using a skeg
I am happy to sail without a rudder as well.
I adjust my skeg quite a bit when I am paddling.
If I my boat is balanced and staying on course, I leave the skeg where it is.
If my boat is turning into the wind, I put the skeg down a bit. If my boat is turning down wind on me, I put the skeg up.
So I put the skeg up when I want to go more up wind than the boat wants to go, and down when I want to go more down wind than the boat wants to go.
If am am happy with my course, and decide to turn down wind, I might put the skeg down a little to encourage the boat down wind and vise versa for a change of course up wind.
mast universal joint
As the designer of Falcon Kayak Sails, I have looked extensive at every universal joint I could find.
I was not happy with any of them for various reasons. My biggest concern was some just pop off when put under stress.
A tiller extension joint is designed to be a tiller extension joint, not a mast universal joint. Any that stay on well, are a pain to put on or take off at the launch site and have easy to loose clevis pins and cotter pins. I think they are a little ugly.
We have engineered and produced a purpose made universal joint that is designed specifically for compact sail rigs.
You can see pictures of what we did here.
http://www.falconsails.com/WhyBuyAFalconSail.php#universal
It is solid as a rock, simplistic, easy to install, and looks great.
There is nothing else available on the market even close to our patent pending design.
paddle sailing up wind
I have been sailing my entire life.
Even with a boat purpose designed to sail, some times going dead up wind is just more work than it is worth & it is time to start the engine.
If you enjoy sailing paddle sailing and working your way up wind is a lot of fun. Generally if my destination is straight up wind, and I am out on a typical paddle, I put the sail down.
The more you practice going up wind, the better you will be able to do it.
When everything is just right, I gain useful propulsion to within 30 degrees of straight up wind.
If conditions are good, I can take a beginner paddle sailor and have them make no paddling up wind progress.
It is a subject a little deep for one posting on a discussion board. I wrote a bit about it on falconsails.com on this page.
http://www.falconsails.com/KayakSailingFAQ.php#direction
maybe not
quote: ā€œReally kayak sailing is a skill that is above and beyond kayaking. It requires sailing knowledge, more advanced decision making skills, paddling skills way beyond what is necessary for normal paddling.ā€
My findings are different.
Most sea kayakers when they try to use Flat Earth sails are thrilled right from the start and get they head around things within one hour. Very few that borrowed my Flat Earth fitted kayaks had prior sailing experience. A few quick instructions on the beach before launching and they usually are sailing straight away.
While this is a private video (was not intended for publication) here is an example of last week sailing of a person that has been sea kayaking for a short time and tried Flat Earth sails for the very first time: http://youtu.be/F8KFNFyaNUg
again, I beg to differ
while the tiller extension on its own might not be the very best mast base (in concept it is very similar to a windsurfing mast base) when used inside the mast and not stressed to vertical loads it is a brilliant inexpensive solution (refer to my blog article).
The Riley tiller extension takes a whole 3 seconds (not an exaggeration) to fit or remove.
But I am sure some other tiller extensions are not as good and some take much longer to fit. I tried the two Ronstan ones, (the rubber and the stainless steel ones) and found them not as good.
it
certainly looks like you were having fun
Upwind sailing dagger boards
I forgot where exactly I saw that video, but I have seen a sail rig that includes dual dagger boards that can be deployed (or not) at both sides of where the mast is. They go down on each side of the kayak hull, thus offering great resistance to sliding sideways. That rig appeared to do pretty good tacking upwind…
It was a man and a woman team in the video (mostly in separate single kayaks). If I find it, I’ll put a link.
This may be…
the sailing system you’re thinking of:
http://www.kayaksailor.com/video-gallery
proper mast universal joint.
GD
You wont really know the difference until you try it.
Enjoy your summer down under and have some great paddle sails.
Patrick
Falcon Sails
www.falconsails.com
Yes, This One
Thanks!
This has me thinking
I’m thinking it might be really fun to get something like a Lazer, or a Force 5 sailboat and learning how to paddle it.
Sailing = Fun
I’m a complete sailing novice, but I’ve used my buddy’s Falcon Sail and took to it pretty quick. I would say I’m a very comfortable advanced sea kayaker with a bomb-proof roll. That being said I didn’t have reservations with heeling over and bracing hard on the downwind runs. It didn’t take long to ā€œfeelā€ when I needed to tack and make sail adjustments. It was hardest for me to get into the rhythm of changing direction, bracing, pulling in or letting out some line so the sails are properly filled. As someone who doesn’t have a sailing background, learning to sail in a kayak was fun and easy. You comfort level in a sea kayak will shorten your leaning curve. I’ve done it both with a skeg boat and a skeg+rudder boat and while I initially thought adding a rudder to the mix would complicate matters even more, I appreciated the rudder and it helped me hold a line on a hard cross wind/down wind run.
Fast is an understatement. With enough wind I had enough speed to curl my hair and then some. I’ve also been out in pretty rough small craft warning conditions and we caught swells with ease, the surfing was especially fun. I have been upside down a couple of times (mostly my fault) and like Gnarly mentions you take a second to gather yourself, loosen your mast line, set up and roll. A quick yank on the mast line and the sail pops and you’re off. From a fit and finish stand point the Falcon is impressive and it does have more of an ā€œengineeredā€ look to the deck connections then the photos shows on his FE sail. It looks like both fold and compact for regular paddling, which I appreciated when struggling to go up wind.
Kayak Sailing
Based on your idea (maybe humor) of paddling a sail boat, I guess you think paddle sailing is not a practical thing to do.
When I started kayaking over 13 years ago, it led to one of my boats sitting at the dock all summer long, and my trailer sailor (a carpi 14) sat in the garage all season not used. Then I pretty much put my life time passion of sailing on a shelf.
I loved the fact I did not have to find a crew any more, was not limited in locations by the fact my keel boat could not be trailer-ed, I was not dependent on the wind for a good time, and my water sport expenses where cut to a fraction of what they where. When somebody said I should get a kayak sail, I thought it was one of the stupidest ideas I ever heard of. I though I will just buy another sail boat if I want to sail.
Then on a whim I bought a sail rig for my kayak, and was amazed at the performance and how much fun it was.
Now I know conventional wisdom about sailing leads to many dead wrong assumptions about kayak sailing. Kayak sailing is a sport in itself. The performance exceeds most peoples expectations. But at the same time kayak sailing is a simple option you can add to any boat.
Your idea of paddling any sail boat does defy conventional wisdom again. I am sure paddling any sail only sail boat will not paddle 1/10th as well as any kayak will sail. I am very sure you would be amazed at how well any kayak can sail if you put a proper rig on it. Anybody who tries paddle sailing in decent conditions ( moderate winds of 10mph are plenty ) is likely to be hooked on it. The beauty of being able to pop up a sail when the wind comes, is an awesome option. It adds a whole new dimension to kayaking.
Just like you should try new foods, you should try new things in paddling. Your horizons will expand a lot faster that way.
Of course he was joking
I once ā€œrescuedā€ a sailboat that had ended up becalmed out on the lake when the wind died down. It was a very small boat only capable of carrying two or three people. I was rowing and had lots of reserve power, or so I thought. Good grief, what a beast that thing was to tow. Progress was terribly, painfully slow. I’ll never do anything like that again simply to be a nice guy (I would if there were some more compelling reason). So yeah, trying paddle even a very small sailboat, even a one-person boat, isn’t something anybody would do by choice.
the offer still stands
the offer still stands from last time: I am happy to test one of your sails and then I will really know how good they are. As long as I don’t have to modify my kayaks too much (hopefully stay anchors and mast base holes line up with existing ones) I am sure I could manage one of your sails. Let me know…
