Wheels don’t appear solid? Their instagram shows a metal cotter pin, but yours is plastic.
Bungee/shock cord (elastic line) will have to be replaced eventually and looks sorta complicated. Should take pics for when replacement needed. Line to prevent slippage would seem to demand non-stretch.
Attachment seems only for plastic kayaks or could damage some composites, esp if tight?
“Made with ASA (Acrylonitrile Styrene Acrylate), a plastic with good mechanical properties and resistance to UV rays.”
Nice but you’re having to pickup more weight because cart is right at the end of the kayak. Normally you only want cart a bit off center so the cart has 90% of the weight.
Wheels are solid rubber. The bungee at the coaming clip is marine grade so for its limited exposure I don’t see it wearing in a hurry. The blue line that holds the kayak is 5mm static line. I found the whole affair to be quicker to install than a center mount type cart.
It’s definitely an end cart so no it’s not going to come anywhere off the sharp part of the stern or bow. Compact, functional and easy to use were the design goals
Neat little cart for situations where portability is the priority. I wonder what the plastic axle clips in the video are called? Sort of a C-Clip with a center pin. Those could be handy for other carts but I couldn’t find anything similar online.
