A tight fit question on a SOT
Looking for ideas. I paddled my S14S for the first time a few days ago. Good boat but the problem is the body I have to cram in it .
The only problem with that is the foot brace/ rudder controls are at max.
Left foot is ok but my right foot is always in peddle to the metal position. On land I wear a brace that helps, but it is plastic and aluminum and heavy so not for the water. I can’t properly operate the rudder control with that foot.
I’ve thought about removing the foot braces and leaving the rudder as a skeg . The other suggestion is to use a push rod for the rudder control.
I paddled it briefly with the rudder up and it responds well but the rudder turns it in a blink.
Any ideas short of sawing off my foot are welcome.
Is it the S14s G2?
I don’t have a fix for you,
But very cool…
https://www.stellarkayaksusa.com/S14S-surf-ski
When you say pedal to the metal, is it that your right foot is always abducted, toes pointed away, when not wearing the brace? I have an idea but I’ll need to play with a Stellar today to see if it’s as easy as my one cup of java brain thinks it is currently.
See you on the water,
Marshall Seddon
The River Connection, Inc.
9 W. Market St.
Hyde Park, NY. 12538
845-229-0595 main
845-242-4731 mobile
Main: [www.the-river-connection.com]
Store: [www.the-river-connection.us]
Facebook: [fb.me/theriverconnection]
Instagram: Instagram.com/marshall.seddon
Yes , my toes are pointed away . Very little flex in my ankle.
Grayhawk, yes it’s a Gen 2. Only took me a few minutes to get over the woo-hoo factor probably because of my COG and the foot issue.
Thank you Marshall. I’ll try those ideas.
Would the full foot pedal, like on most surfskis help?
I am, personally, a fan of the T-bar tiller and a foot rest. Either of those is better than those slidey things that put on that boat. I have higher expectations for Stellar.
