Hello! I could use some advice if you would be so kind…
I recently bought an old fiberglass Necky Arluk 3 that seems to have no more gel coating on the hull. You can feel the cloth but it is completely smooth, almost as if someone removed the gel coating that was on there. (Pic attached) I filled the hatches and cockpit with water and it’s completely watertight. I also paddled it for 12 miles and no leakage. I’m looking to have a finish put on the hull. I’m not looking to redo the gel coat but maybe use a marine paint like Interlux Brightside. (Or should I leave it as is?) Do you think Brightside would be a good choice for this hull or do you recommend something else? Any advice for the painting process? I didn’t pay much for this boat and I’m trying to keep the cost down. Really love this boat BTW!
Thank you in advance for your time.
