any electric kayaks?
Hi
I wanted to buy something like a motorized kayak.
i was looking at mokai.com
any other brands there?
thanks
electric…
…hobie cat is the only other electric powered kayak I know of…It’s a SOT
Ocean Kayaks’ Torque
has an electric trolling motor. Another SOT BTW
Or
– Last Updated: Mar-19-12 2:19 PM EST –
The Mokai is powered by a gasoline engine - it's not much of a kayak really, although it looks cool to me, more like a small hydroplane.
You could also consider putting an electric motor on a real kayak - the Torqeedo Ultralight is somewhat expensive, but is compact and designed for the application, as opposed to just using a regular trolling motor designed for lower speeds.
http://www.torqeedo.com/index.php/us/products/ultralight-403-with-integrated-battery-for-kayaks-and-canoes/products-a-accessories
I have a kayak that's a bit of a dog, and I've been considering motorizing it to have some fun.
PS it looks like the electric motor on the Hobie mentioned above is a dedicated version of the Torqeedo Ultralight.
here’s one
http://www.minnesotawhitewater.com/
scroll to the very bottom of the page
That’s just the Mokai again
and it isn’t electric, it’s powered by a Subaru gas engine.
then there’s this…
http://washingtondc.craigslist.org/nva/boa/2905040063.html
WTF
how about an electric fork?
Maybe start with a tool designed for the job. Get yourself a square stern canoe and an electric motor. If the spray bothers you, put a deck on it.
Wilderness Systems…
used to offer a Pamlico Excel , now called the 160T I think, with an electric trolling motor in place of the rudder.
I don’t know if you could find one, or want to make one, but if you want pics, I think they are still on my hard drive somewhere. We sold the thing a couple of years ago.
Happy hunting,
T
State regs
When you put a motor,electric or otherwise, on a kayak in NC you must register it like a motorboat. You should check your state’s regulations.
Mokai
I have a Mokai that I use for fishing in the larger streams here in the ozarks. It works great when I don’t have a partner to shuttle cars. It will go upstream against any current I’ve run into yet (15 to 20 mph top). It will go in about 6 inches of water with no problem but I weigh only about 165 lbs. It is heavy though about 100 lbs without the motor.
Comes with an electric motor
optional.Check it out !
http://santacruzkayaks.com/
