Need some info on sit on kayak that would be suitable for a beginner thats 5" and 115lbs . needs to be something thats has a keel and is easy to load and unload.
SOT kayak
I purchased a RTM SOT(Disco model)this spring. Check out website as they have other modesl available as well:www.rtmkayaks.com.It is not only sharp looking, but it is fast & handles great. I have (4) other kayaks & I have to say I have used this one by far the most this summer. It is worth checking out. Good luck.
Venus
Venus if you like pink.
Torrent for mild whitewater.
Disco for rougher waters and longer trips.
jim
RTM Disco
My favorite as long as I can stay under 190#
Should be perfect for the OP
Also very reasonable price.
The Venus is shorter, lighter, and easier to cartop, but not nearly as fast, and very, very limited on weight capacity
kayak
thanks for the info ive lookd at several will check it out
One that has a drain hole…
To get rid of all the drama & BS that complicates the normal flow of a mans life. And if that doesn’t work, cut the hole bigger around the seat.
LOL! Chill out, Jeez.
Paddle easy,
Coffee
Why and where
Why does it need a keel? Where will she be paddling. How far will she want to go? How fast?
