I have a Sea Eagle 370 with the better Pro-seats and the main complaint is I don’t have good foot support and consequently my legs and butt suffer after some hours. No foot pegs are installed and the boat also doesn’t have the D-rings to easily attach something. The seats also are not arrested. they friction-fit and when I push my legs, can move back. Currently I use my Drybag squeezed into the bow. My trips are 3-4 hours, but i really would like longer trips, which currently isn’t comfortable.
My initial idea is to use a 2"or larger PVC pipe as a foot support. I would then use an adjustable strap through the pipe and attach the strap with carabiners to the strap of the inflatable OEM seats. That way I wouldn’t push my seat back when supporting my feet. Some potential pitfalls are that the strap could wear when it leaves the pipe, or the pipe indents into the gunwales. I was thinking gluing end pieces on the pipe could avoid the gunwale damage.
Did someone built in a foot support or has a better idea?
the seats likely are good enough, and my current butt-problem is most likely due to the awkward foot/leg situation. so before i look at better seat options, I need to resolve the foot rest issue.
