Has anyone had any experience with canoes made by “Cadorette”?
Recently I ran across a 15’ Fiberglas canoe with “positive flotation” (it has areas at the bow and stern molded into the canoe which are airtight and may contain foam).It was made by Cadorette for a firm in Malone,NY.
I’m in the process of obtaining info from Cadorette in Quebec,Canada but I thought I’d try to find out more than the usual glowing sales pitches from the manufacturer.
Thanks in advance.
bump
bump
I found their website
and to me it looks as though these canoes are built using a chopper gun. I could be wrong but they also make speed boats, almost always built with the chopper gun method. That and 65 lbs. is a little heavy for a tandem fiberglass canoe. They also look like they are using a keel. Something most modern canoes don't have. I would look around before putting my money down. Can you give us the price?
I think there are better ways to go for your money.
Please read "chopper gun construction" on this page from Seda kayaks http://www.sedakayak.com/shared/construction.html
http://www.cadorette.ca/canots.htm
http://strategis.ic.gc.ca/app/ccc/search/navigate.do?language=eng&portal=1&estblmntNo=123456077489&profile=completeProfile
Cadorette canoes
My 1st canoe was a Cadorette & as stated it was a chopper gun piece of junk w/ a keel that weighed a ton (almost). It's a wonder I ever paddled again
If you're thinking of buying one DON'T. If you get one for free plant flowers in it as lawn ornament but don't, whatever you do, paddle it.
C’mon Glen,…
… don’t beat around the bush. Tell us what you honestly think of this boat.
We have had two Cadorette’s for more than 40 years - a 12’ and a 14’. These are not meant for portage trips. Best on large lakes or larger rivers. YES, they are heavy, but after almost 5 decades of relatively heavy use, they look almost like new. YES they have a keel - and they track wonderfully straight. We are in Central Maine, near Waterville. If you have one of these you want to sell, let us know. We’ll probably take it.
MaineBoy-How heavy is heavy? Any guess on the 12 footer? There’s a Cadorette near-ish to me, but too far to just go check it out. I’d be using it mainly as a solo paddler, so weight is a consideration.
