I understand that you were comparing the 12 ft models, which is why I posted those specfications, as well as specifications on a 16 ft Oru model. Your personal experience with the Oru definitively summed up the difference between the two boats. Based on your experience, I figured you also either paddled a Pungo, paddle with someone with a Pungo, or surely assessed the parameters and formed an educated opinion.
However, there are times that seem ordered for an illustration, and this appeared to be as good an opportunity as any. I noticed a number of first time posts asking for kayak recommendations. No better time to discuss the qualities of specific kayaks than when a post queries the speed and suitability of two vastly different boats.
When I post information, I try to present it from a novice perspective. My reply was largely directed in solidarity with Stringās comment about the 140 Tsunami. String appears to be the most experience of the Pungo drivers who post details about the 140 Pungo, which is why I took the time to compare the standard roto-molded version and the Duralite model. I hope that my comparison can preempt a question about whether a Duralite Pungo is any good. The answer is unequivocably yes. Literature from the model year alternately list it as 39 or 43 lbs, which is about 10 lbs lighter than the standard model and about $200 more expensive. Iāll repeat that I would never sell mine, because they are no longer available and are far more enjoyable (possibly faster) and far easier to carry than the standard model. The stability makes it a perfect boat for guest paddlers. Now I like speed more than most, but I donāt mind slowing down to keep water out of the boat. This picture that I posted previously of my grand daughter in a 12 ft x 21 inch wide 120 Tsunami SP, also has her mother in the background paddling my yellow 140 Pungo Duralite kayak (those kayaks have a 12 and 13 inch deck, respectively).
I really do understand why spray skirts are recommended and why peolple use them. The Pungo cockpit is rather large, as you pointed out. The 120 Tsunami SP is suitable for a spray skirt. However, I have taken my daughter and grand daughters out in the kayaks, exploring incrementally further on each trip, and further into open water under increasingly challenging conditions. On that trip, they both did fairly well. None ofbour boats returned with more than a sponge bath mop up, which was mostly water dripping off the paddles. That is hardly flat water, but neither is it challenging conditions for either of our three kayaks (I was in the 145 Tsunami). We all had PFDs, the water was in the 80° range, and you can see by the pictures, the GPS track, and the direction of the wind and waves, as well as proximity to land, that if anyone capsized, we would be blown to the shore. Those concerns are simply a part of route planning and ānavigationā. To put the issue about my not using a spray skirt in perspective, I view that as challenge to my competence and judgement; it categorizes me as a clueless rube. If I ever took unmanageable water into the boat, I wouldnāt need casual observers telling me to get the spray skirt out. However, forum members issue edicts about what other kayakers should dobas an imperative. For some reason, the canoe class on the forum doesnāt seem to do that, and rather offer advice on what works for them. I understand, spray skirts keep water out of boats even if I donāt get much water in my kayak. So I donāt use one, nor do I own a dry suit, or paddle in cold water. I have a stable boat, because I what to remain afloat, not because Iām afraid to roll. I didnāt but a submarine. I have a 240 cm Kalliste but use a 250 cm version and ordered a 260 cm model. I already know that a padfle that long doesnāt make sense, and itāll make my kayak waddle like a duck. I accept that. The Kallistes are still only $470.
As much as I prefer going fast, here is no imperative that I make full speed at all time. If forecast post small craft advisories, I take the 175 Tsunami. In the 175, I only have to drop speed when winds are over 15 mph gusting to 30 mph. Then when I say I drop speed if water washes over the deck, its a matter of going from 4.8 mph to 4.2 mph. In the 145, itās a matter of dropping from 4.2 to 3.8 mph. That speed drop prevents the bow from flying off the wave peaks and plunging in the trough. Now guys like Sing do that all the time, but Iām just not that adventurous.
You can wear your spray skirt, I donāt mind, but I donāt go out when conditions get too troublesome - itās too much like work. An advantage of the Tsunami design is the tall deck of 15.75 inches, high freeboard, the solid primary stability, and the symmetric hull which rides the waves and keeps the cockpit dry. A disadvantage is the high freeboard and deck catches the wind, the wider beam will easily fly off the wave peaks rather than punch through the way Steveās 17 ft x 21 inch Chatham will cut through, and the favorable primary stability will become detrimental as the waves evolve into a curl. Unless you paddle these boats, or the area where I paddle, you really donāt understand how the boats will perform. Iām a fair weather paddler and donāt go out on the water when the conditions donāt suit the limitations of my boats.
There are times that seem well ordered for an illustration, and this appeared to be as good a thread as any, because I noticed a number of recent first time posts about kayak recommendations. No better time to discuss the qualities of specific kayaks than when a person asks about the speed and suitability of two vastly different boats. I agree with your comment about the weight of the Pungo kayaks. Although I have not paddled other Pungo models beyond testing, I have paddled with others using the entire spectrum of models, and I have helped load them. My niece owns a more recent model of the standard 140 and a 120 Pungo, and her brother bought a 125 for his wife the first year that model was offered. We have paddle together on a few occasions.
I simply wanted to add a caveat to your comment about the effort required to paddle the Pungo. Since I have no paddle time in the roto-molded Pungo, I only wanted to point out that the 140 Pungo Duralite is only about .5 mph slower, if that, than the 145 Tsunami.
