My cane seats are coming unzipped - the strip that holds the cane in is coming out.Do I glue it back? With what?
You can get waterproof glue
at any craft store, this is what I use. http://www.jsbeads.com/shop/shopexd.asp?id=23143
It dries crystal clear. Just put it in the slot and cut yourself a blunt edge wedge and pound the spline back in.http://www.grovestreet.com/jsp/onepic.jsp?id=321918 You can also get new cane at most craft stores for about 8 dollars.
Soak the cane.
Soak the cane with some warm water and do what is mentioned above - Push the cane back into the groove with a blunt wedge. I use tightbond woodworkers glue.
I read a past response and used
Tightbond and some plastic clamps.
