Hi All,
Any tips on cartopping a 22ft by 22in tandem
on a honda odyssey factory rails with thule crossbars?
also info on overhang laws.
Cheers
Here is what I did on my pickup
URL=http://good-times.webshots.com/photo/2182228210088080270HHajAE]http://thumb10.webshots.net/t/68
[URL=<a href=“http://good-times.webshots.com/photo/2579738140088080270UvZVpY” TARGET="_new">http://good-times.webshots.com/photo/2579738140088080270UvZVpY</a>]http://thumb10.webshots.net
The cantilevered front overhang with the nesting saddles was not for support, but for stabilization from cross winds at high speeds.
I made it out of 1" EMT and it is bolted to the cross bars and to itself.
I normally on my 18 foot yaks and most canoes never use front tie downs, but with that boat I always did.
If your tandem is a big heavy poly boat, you should probably think about rigid 3/4" galvanized pipe.
Where there is a will, there is a way !
That is similar, in principle, to the
extended cradles we used to make to carry 27’ single sculls.
I think the materials were less than $10
Not counting the saddles.
