Does anyone know the type of plastic used for the chute paddle blades? I’m attempting a repair which will include gluing on the blade–will PVC type cement work?
if this is the Quest Chute paddle from Dick’s, they offer one year warranty. PVC cement is a solvent weld in that it dissolves the PVC slightly to make the two parts adhere. Will only work if the cement dissolves the blade and shaft. Try another product for joining aluminum and unknown plastic. Regardless of choice of glue, remove as much of the old and clean everything well so new bond will take. Also make sure the blade has the correct orientation to the shaft to preserve the adjustable off-set
