Just make sure to get correct size of the Glowire. I use it for camping. It reflects but the stuff I have is way too narrow for deck lines.
I just acquired a new-to-me boat and the deck lines could use some rehab. Any tips I should know before re- doing the lines? I’ve watched a couple of videos, seems straightforward.
If you kayak has 3 or 4 deck fittings in a row in front of the cockpit, consider skipping one of them to give a longer span of deckline between fittings, making it easier to grasp.
Also, some suggest tight decklines, but raised off the deck using small balls or other spacers.
Sorry for my silence, I’ve been away. But thank you all for all of your input and suggestions…one thing I didn’t include was that I’m in Canada, so many options available in the US aren’t available to me (or rather are, but at a hefty cost).
This search led me down a rabbit hole of learning about materials and why some lines are better than others In short, polyester is the best option, and I managed to find a 50m (164’) spool of 5mm polyester with nylon core from Amazon.ca I even got a non-black option (I chose green to go with my yellow boat), which was simply for fun, but also to differentiate between line and bdeck bungees more easily. It’s a LOT more than I need for 1 boat, but I’m sure I’ll find uses for it!
Most boaters at night won’t be have “headlights”, so the effectiveness of reflective decklines and/or SOLAS tape might be a bit limited – but still worth the effort for the little bit of help they might provide. For me, the big bonus is that they also make it easier for you and your boating partners to spot a run-away boat at night if it somehow escapes you, or for those other paddlers to follow you if you have to make an early start/late landing, for fun, or to ride the correct tides and currents.
On a parallel slant, dito for SOLAS tape on your paddle: if you loose it, it will become all but invisible if more than a few feet away from you, specially if all black. And when paddling, even in daylight, flashes created by the moving paddle can make you quite a bit more noticeable.
