Is there a correct method of putting the air barrier foil on a curved surface? Do I cut little slits in the foil to help it curve or should I simply let a pro do the repair work on my yak? FishHawk
Yes … Don’t do it.
Real world info here.
http://www.surfskiracing.com/Technique/Gelcoat_Scratch_Repair.html
Yes
– Last Updated: Jan-23-11 4:57 PM EST –
as Pat mentioned in his post, if you do use Gel, mix hot and get some PVA and brush it on.
Edit: PVA=Polyvinyl Alcohol (so you don't get confused if you go to Wikipedia to look it up).
Accept that you’ll need to sand it…
– Last Updated: Jan-24-11 6:41 AM EST –
...and don't worry about trying to get a perfect surface with the air barrier. If you use "finish" gelcoat (a.k.a., "waxed" gelcoat), you don't need the air barrier at all. Mix, apply, sand, buff, done!
I second Bnystrom’s advice
I followed his directions and ended up with a fantastic repair job. Curved surfaces, flat and right across the keel. Thank you Bnystrom.
