The sticky velcro on our canoe bow foam splash rails has lost it’s stickyness, and I am looking for a good glue to fix it.
In other words, I am looking for a glue that will glue vinyl to foam, (not the high density foam).
Any good suggestions ?
I have given up on contact cement, so please don’t suggest that.
Check out Marine Goop.
You might try a vinyl glue, or a multipurpose PVC glue.
On my model foam planes I would use epoxy…
I would try to get the velcro without the sticky.
thanks, but…
I have marine goop, it is too thick to spread like a thin glue
I am toying with using G-flex, but was looking for a single part glue like a wood working glue
@JackL said:
I would try to get the velcro without the sticky.I am toying with using G-flex, but was looking for a single part glue like a wood working glue
Or thick super glue(CA)
…https://www.hobbylobby.com/Crafts-Hobbies/Model-Kits/Tools-Adhesives/1-Ounce-Extreme-Power-Thick-Adhesive/p/722-GE0867
