Should I be concerned about hull discoloration? What things should I be looking for around the area that is discolored?
Looks to me like there are multiple spots with discoloration. Owner says kayak has only been used around 5 times and has been stored elevated and inside.
Looks like it was stored outside. Over a long period of time the UV rays will deteriorate the polypropylene but that takes a long time. Most likely it’s just cosmetic. As with buying any used kayak, press on every inch of the boat looking for soft spots and cracks. If this kayak seems sound you may be able to revitalize the color with light sanding and oiling. Use the fade as leverage to lower the price.
Bought the boat. I’m not sure why the ad pictures seem to show orange coloring, same boat as the mounts are modifications owner installed, and there is no discoloration. Hatch covers Seem OK. Owner said he took the thigh pads out and now is not able to locate them. Not sure where to start in regards to buying replacements. I’m sure Google knows.
