gps mount
-- Last Updated: Mar-24-08 9:08 PM EST --
looking to mount Garmin 305 on surf ski and kayak. Any suggestions?
my idea
I used a 2in wide strip of aluminum about 8 in long and bent it over and drilled it. A wing nut holds it in place. Had to drill a hole in the coaming of boat and ski. Worked well for 5 years. The gps is taped to the aluminum strip. Have also seen gps glued to piece of v shaped foam that is velcroed. Then you glue velcro on boat. Have also seen a door hinge bolted to boat. Tape the gps to hinge.
Here’s another…
http://www.linckekayakequipment.com/
I just ordered one.
