I bought this Grumman canoe recently and was wondering if I can get any information on it. Anyone have an idea how old it could be? I couldn’t find any makings on it. I’d also like to search for a stern seat.
Check again real close on the deck of the bow for a stamped number, and inside for plates that were usually riveted to the metal covering the flotation blocks, or outside just below the bow plate. It may not be a Grumman, there were several other similar brands. Yours look the ones at my boy scout camp that had been painted red in the early 1960s, the boats were from the 1950s. There are people who are very into these canoes and probably tell you within about 5 years of when it was made, if it is indeed a Grumman. I have an old Smoker Craft from the 1970s that looked pristine until a few years ago when it was damaged in a wind storm.
Is that an 18-footer? If it is a Grumman, and the spacing of the riveting on the stems and keel makes me think that it almost certainly is, then I think it should be an 18-footer because of the layout of the ribs, with three ribs in the center and an extra rib at each end that’s farther away from the central three. I’m not sure that Grummans always had that embossed “G” on the vertical surface of the float chamber (which I think I might be seeing in the first photo), and if that’s the case, then it would not be an especially old boat. If it was built recently enough (I think since the early- to mid-70s), the hull identification number will be coded to tell you the year of manufacture and the name of the builder (in case the builder is in doubt). Others here will know more (including how to interpret a modern, coded I.D number, but you can Google that too).
By the way, I would suggest that you contact the present-day builder, known as “Marathon”, and see if they can supply you with the seat that you are looking for.
Hey, I don’t mean to be rude and knock your new canoe purchase… but I think maybe you were scammed…
At the very least make sure you wear your PFD!
Uh, Grumman also built some very tough fighter planes, and as I recall paddling Grummans 50 years ago, their canoes were about as tough!! About as heavy as well, man I remember developing teamwork as an 8 year old racking those beasts.
Ladder, heck, anybody can pick up a ladder
After WWII Grumman had a lot of left over aluminum from their aircraft division, so it went into the manufacture of canoes. They made at least three different weights, lightweight thin skin (I still have one of those), midweight ( what most people have) and camp weight (still found in many BSA camps and presumably in the movie “Deliverance”).
Looks like the 15 ft. Grumman canoe I purchased in 1964, except mine is a bit cleaner. My brothers and I used to surf with it in the Gulf and fish in it in the rivers around Sarasota. My youngest son and I used it last month on the Withlachoochee River. A great boat that will last a lifetime or more.
My college roommate had one at his grandmother’s house on Pawly’s Island in SC.
We also tried to surf it. That didn’t work out too well.
The front seat frame looks Grumman, but the ribs and keel rivets do not. On this vintage Grummans there was a small oval brass plate with the serial number and model on the front deck. if its missing the rivet holes should be visible. As for a replacement seat any Grumman dealer can get it. Oak Orchard Canoe has them in stock normally and you can order by phone or internet. www, oakorchardcanoe.com or 585-682-4849.
Thanks! It does look like the serial number plate is missing, I see the rivets.
The curved/angled from decks instead of straight across would lead me to believe this boat is from before the mid 1960s. I would guess a 1950s boat.
I agree the 5 ribs makes it look like an 18’ model
Contact Marathon Boat Group about replacement seat options. They still make Grumman Canoes in the same factory.
https://www.marathonboat.com/grummanboats.asp
Dude, I recently carried 32 foot ladder on top of my 15 foot Grumman on my Ford Ranger.
That canoe made a great ladder rack!
I think you are right about this not being a Grumman.
It’s a decent copy, but not a Grumman.
The iconic Ron Drummond Dana point photo. Long, long. long ago. I also know some kayak surfers who have surfed their Aluminum aircraft carriers in big surf. I’ve also helped rescue a few Zonies who thought they might like to try in La Jolla .
I’ve owned two Grummans, both 17 standard weights - one was stolen from under the porch of a place where I lived and I replaced it with the one I now own in '78. I don’t recall how the HIN was marked on my original, but the one I still have has a stamped plate riveted onto the hull. The curve in the deck plates doesn’t look like any Grumman I recall seeing. Mine are straight across and rolled downward, presumably to make them easier to grip for carrying. That lends credence to the idea that it might be a near copy made by someone other than Grumman.
If you contact Marathon/Grumman to see about a replacement seat, you might inquire about a) the number of ribs (I think the lightweight Grummans, and maybe the heavy-duty ones also, had extra ribs to add strength to the lighter skin model) and b), Older Grummans used fewer but larger rivets on the stem and stern. It might be possible, in the absence of a stamped HIN, to at least approximately date the boat by the size and number of stem/stern rivets. Folks at the manufacturer probably get such inquiries often enough that they could help you on this.
As a kid I was a flying model airplane hobbyist as well as a paddler. This, of course, led me to a particular interest in Grumman aircraft. As Daggermat pointed out, this made them experts in building very strong reasonably light (comparable to wood/canvas) aluminum products.
They started out building truck bodies (which they still do) but then added the construction of floats for Loening Aircraft amphibious and float planes in the 1920s. If you can imagine the pounding those floats would take on landing in waves… and they had all that under their belt before they built their first actual aircraft of their own. And they’re noted for carrier aircraft - which also have to be able to take a beating both in combat rolls but routine carrier landings. Rugged is what Grumman is all about.
We paddled Grummans for years. They were everywhere. It was the common boat in the Boundary Waters in the 1980s. I have portaged them all over the place.
They are durable boats with full ends making them relatively slow. They have minimal rocker and come with a keel. That makes them hard to turn on rivers. They stick on rocks. They are heavy. But they last a long time if not abused.
But they do track straight on a lake.
Does it track straight? That really depends on who is paddling it. Much easier tandem than solo and now a days I might even try a kayak blade because I’ve gotten lazy
Soloing one without a load on a windy day, you’ll get kicked around. They present a lot of surface to the wind. That’s not unusual for many tandems under those conditions though. The absence of any discernible rocker probably helps the tracking as much as the presence of a keel.
That canoe is long gone, but it had great stability and tracking. I never paddled it solo but have paddled it while the front passenger just eent along for the ride. Having that ballast up front had to help. Didn’t have any problem keeping it tracking straight and don’t think I had any special skills. Also had good enough stability that we could switch front seats without feeling tippy.
It had all the vices mentioned, as well as being noisey, and cold metal, but it waa a very forgiving boat and fast at 17 ft. I think I would prefer an aluminum to fibrrglass, but that is probably more nostalgia talking than logic. I like the boat.
