I tend to buy my contact cement in small quantities, as my projects are on teh small side and I don’t want to waste money on a large can.
I needed cement recently and lo and behold it appears that Weldwood has abandoned the small glass bottles in favor of plastic ones. Every bottle I looked at, in two different stores (neighborhood hardware and big box) was swollen. I bought one, and I believe that the quality of the glue is either lower or the packaging is compromizing the glue.
Anyone else experience this?
Buy it in cans, instead
You can get the pint cans pretty cheap and they last for years. I haven't had any problems with them drying up in between uses. BTW, I recommend getting the gel version rather than the liquid, as it stays in place much better when you're applying it.
I have one
a small brown glass bottle of contact cement, bought it at Lowe’s not too long ago. Works great.
Make sure you are using the original and
not the nonflammable. The nonflammable (green or turq color label) does not work as well. Original is in red label.
Additional info: In other adhesive products I have found their gel and/or quick versions do not work as well as the original liquid normal drying products. So may want to test the weldwood gel before using it on everything.
Mick
