Is there a hull width requirement in the tandem canoe class you are entering? Most rec canoe classes have a max length of 18’6" require the hull to be proportional to keep out skinny boats. In a 22’ boat, I take it you would be in some sort of unlimited class in which case you might be at a disadvantage if there are a lot of true racing boats in the mix.
What are the rules in the class you would enter it in? Since your boat is 22’ I am assuming is an unlimited class of some sort, so if you have two paddlers and use double blade paddles you could be competitive. If there are a lot of real racing boats in the class though not so much. Some times its better to go small and run in a rec kayak class rather than have to be in there with the big dogs.
Nothing I own will do 8.5 mph even in sprint mode and it wouldn’t be for 2.5 miles my heart would be on the deck. Regular kayak class may be the best choice 18’ or less I’d use my CD Solstice GT.
