How to add accessories Ocean Kayak
Afternoon, Fellow Yaks
I have here a Ocean Kayak Malibu Two XL. I need your opinion on which hatch to purchase and if you recommend a specific hatch. I do not want to go with a Gaspachi Round Hatch instead im interested in a 6 inch screw hatch like:
http://www.amazon.com/Beckson-Twist-Out-Plate-6-Inch-Screw-Out/dp/B00144EL1K/ref=sr_1_3?s=sporting-goods&ie=UTF8&qid=1435607914&sr=1-3&keywords=kayak+hatch&refinements=p_85%3A2470955011
I like the clear hatch because I can see into the storage or this hatch
http://www.amazon.com/Diameter-Hatch-Kayak-Fishing-Rigging/dp/B00SCL1TKO/ref=sr_1_1?s=sporting-goods&ie=UTF8&qid=1435608134&sr=1-1&keywords=kayak+hatch&refinements=p_85%3A2470955011
Appreciate all the recommendations as possible.
[attachment:1]20150627_164137.jpg[/attachment]
SeaLect Designs
I installed a SeaLect Designs 6" round on a boat I no longer own which is very much like the one you mention with the clear option. i got with the bag that goes inside. 6" was a bit tight for even getting my largish hands into, which sometimes was annoying. Make sure you have a flat spot large enough on your deck to put this, and best to put it in a spot that is normally above water (in case you don’t seal it perfectly).
Use Lexel to seal everything up. Amazon seems to be suggesting something called Goop, which I have not clue would be good or not.
