I’m an intermediate maybe bordering on advanced paddler and hoping to become more serious. I need to buy my first isup board.
I’ll just brain dump what I know and tell you what I am confused about.
It’s very easy to find the advised length of the board with a simple google. I’m going to assume that longer boards are harder to turn? Every website that sells a SUP has SEO’d the hell out of their webpage and has a chart for you. I understand that lengths range from 9 ft. to 12 ft. I’m average height male.
Wider iSups are harder to turn but balance better. I have good balance, so I’m fine with the lower end of 30-33.
I’m actually not sure about thickness, but honestly this is one of the things that I could care less about. I’m pretty sure that thickness is the least important factor, but they seem to range from 5-7.
The weight of the board probably matters for acceleration, but again not one of the bigger factors as far as I can tell.
The capacity is where google starts to fail me. I’m pretty light. I’m at 130 lbs or 59 kg. What’s unclear is that all these websites that have managed to claw their way to the top of the Google search results will say that you just need to be below the capacity, but others will say you want to have the capacity that is as ‘right’ as possible because if you’re too heavy or you’re too light, you’ll have problems. The board sinks too much or doesn’t go into the water enough? I would appreciate some clarification!
Apparently volume is also a way to pick the board? From what I’ve seen online, I’ll see things like take your weight and convert it into kilograms and then double it. This calculator I found seems genuine. SUP Calculator - SUPwest
PSI also seems like higher is better. PSI influences the rigidity of the board, so if the board can accept a higher tolerance of PSI, then it’s going to feel more rigid. I assume.
hopefully I got that right?
If that’s all correct, here’s my personal dilemma.
I found an amazing deal on a racing board. It’s 12’6”, 30” wide. It’s a bit long for me, according to the charts, but it looks like all these racing boards are this long. But the real problem is that it’s 300 L. This is way over the 59kg x 2 = 120 (beginner) 59kg x 1.4 = 84 (advanced?) suggestions I have seen.
Could any experienced SUPers please help me walk through the selection/constraint process? Other than if I got all the selection rules right, at what point should I say no to a board’s liter number because it’s too high or low for me (all-around SUP and touring/racing SUP)?
