Update: although I haven’t seen any unexpected scratches on the hull, I used some Loctite adhesive to glue some closed cell foam to the black plastic parts in the cradle. That was a year ago and the foam is peeling off. Turns out the extreme heat of late probably melted the adhesive or cause the foam to contract and break the bond. The reason matters not, I suppose, but the pads are peeling off.
I’ll need a solution for removing the old adhesive, since I don’t think I can spray more on top of it and get a good bond. The Loctite website says cooking oil, vinegar or even vodka will dissolve the glue.
Before I go making a giant mess…does anyone have a proven method for removing dried spray on adhesive, like Loctite?
Of course second question is: Now that I know Loctite isn’t the right product, what should I use next time to glue some foam to the rack?
What adhesive did you use? That’s how I placed mine, using Loctite spray adhesive. Lasted a year then peeled up. I’ve been spending the last hour trying to dissolve the residual glue to try again.
Go to the hardware store and ask for contact cement. The same stuff they adhere formica countertops with. Use a brush. Apply to both clean surfaces. NO Dust. No residual glue. Let dry. Put both treated surfaces together. Apply pressure. Try “Weldwood Contact Cement”
