I want to glue a clip inside my plastic kayak for the pump. I want to glue it between my knees. What kind of glue will glue to a plastic Current Design or Romany?
Lexel
The stuff you use to glue in the bulkheads.
plastic glue
What might that be?
West Systems
G-Flex
for plastic - use bolts
For a plastic boat, I used bolts. Not much really sticks well to the plastics used in rotomolded boats.
Glues should work fine for composite boats.
Lexel
It’s the product name. At the hardware store in the adhesive section look for the caulking tube that says “LEXEL”
Yep
I’d use bolts as well. A clip like that will be subject to some high forces which might pop a glue joint.
X’s two
It is made for especially repairing plastics
