The handles at each end of my Assateague need to be replaced. There are two Phillips heads on top but I can’t possibly reach the nuts. Couple of questions:
Do these fasteners have captive nuts on the other side or is there a special tool to reach them?
Are the handles themselves readily available? Anyone have a source?
Maybe you could drill out the screws from the top, then push the screw shank and attached nut down into the hull where a little shaking should get them within reach. Then, stainless pop rivets to attach the new handles.
The rear is pretty much a mirror image, the handle is about 3.5 ft behind the hatch. I’d like to sell the kayak and the SportsRig trailer but I’d rather repair the handles first.
Tried that on my CD Titan I restored and found it impossible. Same piece of hardware.
I was trying to remove lifting handle hardware at front tip of the bow.
Might have a shot at the strap handle with stick method. Yes as advised above hang hull upside down . Take 1/2 wooden dowel and cable tie and gorilla tape a open end wrench to it or a socket on a small 1/4" breaker bar. Use 12 point socket or box wrench.
I hang my boats from upper deck with rope. That way I can adjust height to be comfortable when I’m standing up. Makes a huge difference in how long your patience will last not to mention your body.
You’ll need two people with a bit of mechanical skills to steady hull and remove bolt while one holds nut on inside of the hull.
Measure and mark stick on exterior where bolt is to opening then when you put it in you’ll be somewhat close and feet it.
“We usually have our tools extender to do that kind of job. Our tool extender is a metal or wood pipe that we tape the tool to.
Hope this help, have a great day”
It appears I’ll attempt this as well as the suggestion to hang it upside down. We’ll see how it goes!
