I’m after some advice for my inflatable kayak please!
I’ve had it about 3 years now and the last couple of times I’ve used it, its not inflating to full capacity, it gets so far then just kinda stops… I can’t find any punctures it just doesn’t seem to get past a certain point, there’s a crease on one side that now stays creased… I’ve tried new valves but still no luck
I’m with High_Desert
The pump seals aren’t able to hold the pressure. Could be that you could take the pump apart and fix the gaskets, might be a new pump. Sometimes on pumps the gaskets dry out. Depending on the material you can sometimes oil them or replace them.
