Tried to post this last night but seems my post cannot be found…so will try again:
The seat in my Greenlander Pro broke again. Although I have come to like the seat, I can’t deal with it breaking again so am going to replace.
I am not real crazy about foam seats so it would seem that the Kajaksport seat would be best.
I am wondering the best way to go about installing it…it would seem that the ideal solution would be to cut out the factory seat leaving some portion of the seat still attached to which I could bolt the new seat.
The problem is that the seat is broken off so high that this is not really an option so I am not really sure where i would bolt the new seat and am not really crazy about drilling into my boat if I can prevent it.
Any advice?
thanks
Matt
Post it here…
http://www.kayakforum.com/cgi-bin/Building/index.cgi/noframes/
Even though it’s a wood boat builders site, you will get loads of suggestions. You HAVE TO show a photo of your broken seat and maybe the kajak one. Otherwise it’s a guessing game.
My suggestion: have somebody who knows what they are doing repair the seat. Anybody who works with epoxy and glass can repair that seat and beef it up so it will never break again.
Repair
If you’re happy with the comfort of your current seat, have someone repair it for you or DIY. It’s not that difficult to work with fiber glass. The repair can be made as tough as you like It depends of how many layers of cloth you use. Make sure that it’s repaired on both sides and with a good overlap.
Repaired seat on NDK Explorer
The seat on my Explorer broke on the previous owner. Broke where it hangs down from cockpit. He had it repaired at the dealer where he purchased it. They repaired it with fiberglass and epoxy, wrapping the break with fiberglass. Repair is still holding 3-4 years later.
Dave
Agree with all
and in fact I think as you progress with your paddling passion you would benefit from learning how to work with glass, resin, etc. That will serve you well in the future. Maybe have a pro fix the seat and give you some training as he/she does??
Okay…
I’ll try repairing it again. I already did so once.
The first time I used quick set epoxy to glue the seat back in place to work with and then laid 3 layers of glass cloth on the exposed side of the seat only using epoxy resin.
Perhaps I need to do both sides this time. Hard to get to the boat side though as there is little space.
Maybe I will try wrapping some epoxy cloth around it as if I were taping it back in place with duck tape.
Also have been told that finding stiff foam to put under the seat for support will help. Will have to try that as well.
Any other suggestions on how to make the repair last this time?
Matt
post your question on NDK owners site
I’ve seen many versions of the same repair.
http://groups.yahoo.com/group/NDKOWNERS/
Lyn
Foam
Yes, fitting minicell under the seat tightly in several places will make your repaired seat almost bombproof. Key is to provide plenty of support on the seat bottom so there is less stress on the hangers. Good luck with your repair!
Good advice
I agree with Ret and Carl, the keys to a successful repair are completely wrapping the break with glass and having sufficient foam support under the seat to take the weight off the hangers. If you do this, the repair should hold.
Best of luck!
And ensure that…
You are making a structural bond by fusing the new glass to the old fiberglass substrate, preferably using a common binder (polyester resin vs epoxy). Glass simply laid over gelocat will certainly fail.
link exchange
[Penis Enlargement Devices Reviews](http://www.devicesreviews.info/)
[Penis Enlargement Exercise Program Reviews](http://www.exercisesreviews.info/)
[Penis Enlargement Patch Reviews](http://www.patchesreviews.info/)
[Penis Enlargement Pills Reviews](http://www.pillsreviews.info/)
[Top Penis Enlargement Devices](http://www.topdevices.info/)
[Top Penis Enlargement Exercise Programs](http://www.topexercises.info/)
[Top Penis Enlargement Patches](http://www.toppatches.info/)
[Top Penis Enlargement Pills](http://www.toppenispills.info/)
[Best Penis Enlargement Devices](http://www.bestdevices.info/)
[Best Penis Enlargement Exercises](http://www.bestexercises.info/)
[Best Penis Enlargement pills](http://www.bestofpills.info/)
[Best Penis Enlargement Patches](http://www.bestpatches.info/)
[Penis Enlargement Device](http://www.penisenlargement-device.info/)
[Penis Enlargement Patch](http://www.penisenlargement-patch.info/)
[Penis Enlargement Exercise](http://www.penisenlargement-exercise.info/)
[Penis Enlargement Pill](http://www.penisenlargement-pill.info/)
[op Skincare Products](http://www.topskincare.info/)
[Best Weightloss Reviews](http://www.bestweightlossreviews.info/)
[Best Semen Enhancer](http://www.bestsemenenhancer.info/)
[Attract Woman](http://www.attractwoman.info/)
[Mens Articles](http://www.mensarticles.com/)
[Best Penis Stretcher](http://www.bestpenisstretcher.info/)
[Best Penis Extenders](http://www.bestextenders.info/)
[Breast Enlargement Product Reviews](http://www.breastenlargementreviews.info/)
[Best Hair Removal Product Reviews](http://www.besthairremover.info/)
[Best Anti-Aging Product Reviews](http://www.antiagingreviews.info/)
[Best Quit Smoking Product Reviews](http://www.quitsmokingreviews.info/)
[Penis Health Exercise Program Review](http://www.penishealthreview.info/)
[ProEnhance Penis Patch Review](http://www.proenhancereview.info/)
[ProSolution Penis Pills Review](http://www.prosolutionpillsreview.info/)
[FastSize Penis Device Review](http://www.fastsizereview.info/)
[Volume Pills Semen Enhancers Review](http://www.volumepillsreview.info/)
[SzeGenetics Review](http://www.sizegeneticsreview.info/)
[Proactol Weightloss Review](http://www.proactolweightlossreview.info/)
[Review On Sizegenetics](http://www.reviewonsizegenetics.info/)
[My SizeGenetics Review](http://www.mysizegeneticsreview.info/)
[SizeGenetics Review](http://www.review-sizegenetics.info/)
[SizeGenetics Extender Review](http://www.sizegeneticsextenderreview.info/)
[SizeGenetics System Review](http://www.sizegeneticssystemreview.info/)
[SizePro System Review](http://www.sizeprosystemreview.info/)
[ProExtender System Review](http://www.proextendersystemreview.info/)
[VigRX Plus Penis Pill Review](http://www.vigrxplusreview.info/)
[Tips On Skincare](http://www.tipsonskincare.info/)
[Weightloss Diet Guides](http://www.weightlossdietguides.info/)
[Solution For Weightloss](http://www.solutionforweightloss.info/)
[Best For Weightloss](http://www.bestforweightloss.info/)
[Penis Enlargement Jelqing](http://www.penisenlargementjelqing.info/)
[Penis Enlargement Drugs](http://www.penisenlargementdrugs.info/)
[Penis Enlargement Tablets](http://www.penisenlargementtablets.info/)
[Herbal Penis Enlargement](http://www.penisenlargementherbal.info/)
[Penis Enlargement Scam](http://www.penisenlargement-scam.info/)
[Penis Enlargement Guide](http://www.penisenlargement-guide.info/)
[Penis Enlargement Studies](http://www.penisenlargement-studies.info/)
[Penis Enlargement Methods](http://www.penisenlargement-methods.info/)
[Penis Enlargement Secrets](http://www.penisenlargement-secrets.info/)
[Homemade Penis Enlargement](http://www.homemadepenisenlargement.info/)
[Penis Enlargement Techniques](http://www.penisenlargement-techniques.info/)
[Penis Enlargement Tips](http://www.penisenlargement-tips.info/)
[Penis Enlargement Surgery](http://www.penisenlargement-surgery.info/)
[Penis Enlargement Hypnosis](http://www.penisenlargementhypnosis.info/)
[Penis Enlargement Creams](http://www.penisenlargementcreams.info/)
[Penis Enlargement Pump](http://www.penisenlargement-pump.info)
[How To Measure Penis](http://www.howtomeasurepenis.info/)
[Penis Enlargement Forum](http://www.penisenlargement-forum.info/)
[Penis Size Debate](http://www.penissizedebate.info/)
[Penis Size Survey](http://www.penissizesurvey.info/)
[Online Pharmacymeds](http://www.onlinepharmacymeds.org/)
[Pharmacy Chicago](http://www.pharmacychicago.info/)
[Pharmacy Dallas](http://www.pharmacydallas.info/)
[Pharmacy Detroit](http://www.pharmacydetroit.info/)
[Pharmacy Minneapolis](http://www.pharmacyminneapoli.info/)
[Pharmacy Seattle](http://www.pharmacyseattle.info/)
[Pharmacy New York](http://www.pharmacynewyork.info/)
[Pharmacy Philadelphia](http://www.pharmacyphiladelphia.info/)
[Pharmacy Washington DC](http://www.pharmacywashingtondc.info/)
[Pharmacy St Louis](http://www.pharmacystlouis.info/)
[Career Training Guides](http://www.careertrainingguides.info)
[FengShui Tips For You](http://www.fengshuitipsforyou.info)
[URL=http://www.bestdatingtips.info">Best Dating Tips
[URL=http://www.datingrelationshipstips.info">Dating Relationships Tips
[URL=http://www.datingwomenguide.info">Dating Women Guide
[URL=http://www.freedatingadvice.info">Free Dating Advise
[URL=http://www.wheretodate.info/">Where To Date
[URL=http://www.freesexarticles.info/">Free Sex Articles
[URL=http://www.sexadvice4men">sex Advice For Men
[URL=http://www.sexguide4men.info">Sex Guide For Men
[URL=http://www.sexhowto.info">Sex Tips For Men
[URL=http://www.sextips4men.info">Sex Tips For Men
[URL=http://www.womenhealthcenter.info">Women Health Center
[URL=http://www.womensexualhealth.info">Women Sexual Health
[URL=http://www.healthonfemale.info">Female Health
[URL=http://www.womenarticles.info">Women Articles
[URL=http://www.womenhealth-wellness.info">Women Health Wellness
Penis enlargement pills, how they work
A huge plus for SizePro is that it is doctor approved. Many clinical studies show a great significance in it’s ability to prevent impotency in men. It increases virility as well as stamina during sex. SizePro Pills also enhance penis size in most men. All of the ingredients are all-natural and work both the body and the mind.
http://www.pills-research.com/
Male Enhancement Pills are very helpful for those who are suffering from male infertility issues. By taking the pills in a right manner slowly and gradually sex life can be much improve. You can read Penis Enlargement Reviews and I hope you will clear your all doubts. http://webmdmen.com/fck-power-the-most-intense-male-enhancement-pill/
